i think im getting compressor surge with the hks ssq...
Old Oct 3, 2005 | 11:09 AM
turbotime's Avatar
Default i think im getting compressor surge with the hks ssq...
ok been doing some reading and what i discarded as "normal operation" may actually be compressor surge. Can someone verify if this is or isnt:
Goin medium speed under low load 0 >= boost <= 5psi i get a blow off that sounds like cha cha cha cha.
>5psi i get a distinct chirp
is this surging or is it normal for the hks ssq? If it is surging will simply adjusting the bolt on the bov fix it? Or maybe i need to run it off a better vacuum source? here is how it is run now:
Old Oct 3, 2005 | 11:14 AM
turbotime's Avatar
after more reading apparently this is normal for the hks? i just want to make sure cause it seems like i have a lot of turbo lag i dont reach a full 10psi til like 4-5krpms
Old Oct 3, 2005 | 11:17 AM
Soccerking3000's Avatar
Default Re: (turbotime)
"T" the bov off a stronger vacuum source, thr fpr is a much to small tube, go with the brake booster line you'll see a difference and if that doesnt fix it mess around with the bolt, but dont loosen it to much cause ti wont hold boost then
Old Oct 3, 2005 | 11:20 AM
turbotime's Avatar
is the brake booster the big line on the top front right of the intake manifold, it goes to where the brake fluid resevoir connects to the firewall(brake booster i assume) right?
doesnt that seem like an absurd amount of lag (current setup)?
Old Oct 3, 2005 | 11:22 AM
RacerXI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">is the brake booster the big line on the top front right of the intake manifold, it goes to where the brake fluid resevoir connects to the firewall(brake booster i assume) right?
</TD></TR></TABLE>yes
Old Oct 3, 2005 | 11:23 AM
turbotime's Avatar
money, ill hook it up and see if that cuts the lag, cause right now its pretty laggy, but once i get past 4.5k ZOOOOMMM boost like a ****
would adjsuting the bov bolt cut lag too? if so would i want to tighten it or loosen it? im only running about 10psi (after the creep)
Old Oct 3, 2005 | 12:01 PM
BoOstedEM1's Avatar
What size turbo you have???
Old Oct 3, 2005 | 12:09 PM
turbotime's Avatar
its t3/t4 turbonetics, the one that comes with the DRAG kit...
Old Oct 3, 2005 | 12:14 PM
Muckman's Avatar
Moderator in Chief
damn man.. 7 threads on page 1 of this forum are started by you.
Old Oct 3, 2005 | 12:15 PM
turbotime's Avatar
yeah, slow day
Old Oct 3, 2005 | 12:18 PM
B16Civic93's Avatar
the same thing happens with my greddy type s bov. and i have ALL of my vac sources coming off theline that the fpr is tied into.
i should probably get a vacuum box, however if i did that would i tie it in where the brake booster line is since it's a bigger line or should i just use one of the smaller ones? i dont want to take too much away from the brake booster(not sure if it matters how much you have off of one connection)
sorry to thread jack.
any help is appreciated.
Old Oct 3, 2005 | 12:20 PM
turbotime's Avatar
from what i understand its BEST to give each thing its own vacuum T and use a good sized vac port for your BOV..
Old Oct 3, 2005 | 12:23 PM
wantboost's Avatar
Who is Mr Robot?
yea each needs its own vacuum source... and 4-5k for 10psi on a drag kit is normal, not much turbo lag
Old Oct 3, 2005 | 12:24 PM
turbotime's Avatar
damn that sucks if thats normal, ill still hookup the bov to the brake booster, every lil bit helps
Old Oct 3, 2005 | 01:30 PM
as i said also make sure the bov is adjusted correctly otherwise it wont hold boost and leak, making it take longer to reach 10 psi or whatever
Old Oct 3, 2005 | 05:11 PM
turbotime's Avatar
are there instructions anywhere on how to adjust it?
Also- will T'ing off thebrake booster reduce turbo lag? How? Or, what would be the advantage of doing this as opposed to the above setup?
thanks, sorry for my turbo noobness
Old Oct 3, 2005 | 05:26 PM
notanotherSC61's Avatar
turbo lag is caused by the turbo spooling up slowly. Has nothing to do with the bov. The only reason that this is making this sound is because this is a low boost pressure and the bov spring is at a higher tension causing the valve to bounce. Normal for low boost. Also like earlier stated before this can be caused by a poor vac source. Buy a vac manifold or make one. THis way all your vac sources are consistant.
Old Oct 3, 2005 | 05:35 PM
turbotime's Avatar
what about adjusting the valve, how do i make it tighter? is that what will ensure bost isnt leaking?
and would having the BOV hooked to the FPR vac cause the FPR to perform poorly?
Old Oct 3, 2005 | 05:41 PM
tony1's Avatar
The HKS bov shouldn't ever leak because the valve is inverted. The boost actually holds it shut.
Old Oct 3, 2005 | 05:45 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">The HKS bov shouldn't ever leak because the valve is inverted. The boost actually holds it shut.</TD></TR></TABLE>
i said the same, its design shouldn't allow it to leak.
but, we've had them leak above 28psi on a couple STi's.
Old Oct 3, 2005 | 05:47 PM
tony1's Avatar
Default Re: (PhoenixTurbo.com)
That's just the built in safety device so you don't blow the motor up. lol
Old Oct 3, 2005 | 05:49 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">That's just the built in safety device so you don't blow the motor up. lol </TD></TR></TABLE>
hahaha, on a 35R? or 4088R?
Old Oct 3, 2005 | 05:51 PM
tony1's Avatar
See, the bov knows that's too much turbo for that lil ole boxer engine.
Old Oct 3, 2005 | 07:26 PM
93turbo16's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">See, the bov knows that's too much turbo for that lil ole boxer engine. </TD></TR></TABLE>
Isn't that the truth.
OrangeBoost
Jun 4, 2006 10:16 AM
R6E6I6D
Dec 4, 2005 11:58 AM
Nextelbuddy
Jun 12, 2004 06:39 PM
_Endless_
Aug 30, 2002 06:30 PM
Smoothy
Nov 14, 2001 08:48 PM
