CEL 22 vtec pressure valve
all i am getting is a code 22 and my car wont start. its a h22 in a civic and has never been started before. dizzy reads good. dont know whats going on.
then you have more than just a code 22 then. you car should def. start, even with the vtec code... you just wont have vtec. sounds like you have some other things to check out in the mean time.
if you car is obd1 then look at this thread pics should be self explanatory:
https://honda-tech.com/zerothread?id=1171263
then these threads that all go over the code 22 things you can check for like oil level, wiring, ground, etc:
https://honda-tech.com/zerothread?id=1361377
https://honda-tech.com/zerothread?id=1338121
https://honda-tech.com/zerothread?id=1295422 <-- H22 also
usdmEHboy
Apr 14, 2007 08:23 AM
Fuster_Cluck
May 15, 2003 10:05 AM
