anything in specific I have to do to a B18c....
Old Mar 3, 2002 | 10:01 AM
infamousALLMTR's Avatar
Default anything in specific I have to do to a B18c....
Im wondering about the mount brackets, and if thes will just pop right in to a 92 vx or do I have do get diff. engine mounts. I know all about the tune up I have to do to the engine before it goes in but just need help with the actual drop....(engine mounts) if anyone knows which engine mounts I need plz add to this. Thanx
Oh ya when I order the engine should I ask for the wiring harness or does it come with the engine.
[Modified by Redracinghart, 11:03 AM 3/3/2002]
Old Mar 3, 2002 | 06:16 PM
Jared's Avatar
Default Re: anything in specific I have to do to a B18c.... (Redracinghart)
Use all the mounts, shift linkage, and axles from a 94+ Integra and everything will drop right in.
Old Mar 4, 2002 | 09:51 AM
Default Re: anything in specific I have to do to a B18c.... (Jared)
so I dont use my mounts on my civic right now... ok sounds good.
Old Mar 4, 2002 | 10:50 AM
Katman's Avatar
the only real mount you can re-use from your civic mounts is the TOP tranny mount. That's it.
You need the rest of the bracket-mounts from a 94+ integra. I'm talking about the stamped steel mounts, not the rubber motor mounts -- you can reuse all of your civic's mounts that have that black rubber inside of them, unless they're damaged, you might want to look in getting a prothane mount stiffener kit.
Old Mar 4, 2002 | 11:23 AM
Default Re: anything in specific I have to do to a B18c.... (Katman)
would I ask that these be included with the swap or just get them a local junk yard?
Old Mar 4, 2002 | 02:57 PM
Katman's Avatar
by all means, try and get these mounts with the engine!
Old Mar 5, 2002 | 06:56 AM
LXguy's Avatar
Hey:
Get the mounts with the engine. You are going to need to use the Integra mounts for just about everything.
On the lower front engine mounts (the one you have to mess with to change the belts), you will need the INtegra mounts on the motor, but the "half donuts" that attach to the body will need to be from your Civic.
Get the wiring harness with the motor.
Good Luck
Old Mar 5, 2002 | 10:24 AM
Default Re: anything in specific I have to do to a B18c.... (LXguy)
thanks should have this in buy early april and then will show pics and a documented installation guide.
EG6Boy702
33
Apr 27, 2009 03:55 PM
Poroshok
Jul 16, 2007 07:12 PM
92 CIVIC HATCH VX
Nov 11, 2005 10:28 AM
Drew Peacock
Dec 3, 2004 03:31 PM
vtecmike1
Nov 19, 2003 07:19 AM
