Anyone running a JUN III setup?
Old Mar 3, 2002 | 07:11 AM
Liquidx02's Avatar
Default Anyone running a JUN III setup?
Im currently running JUN III on 12:1 compression. Im trying to figure out the right fuel pressure and ignition timing to run at. Any Info is appreciated
Old Mar 3, 2002 | 03:42 PM
HPilot's Avatar
New User
Default Re: Anyone running a JUN III setup? (Rattlesn8ke)
What are you using to tune the ignition timing? Fuel pressure should be around 45 psi. I have a complete tuned fuel/ignition table from a Jun stage 3 b18c5. Base ignition was set at 14 btc, but ignition is dependent on rpm and MAP.
Old Mar 3, 2002 | 05:44 PM
alexboy's Avatar
Default Re: Anyone running a JUN III setup? (HPilot)
At idle mine is around 45
VegasInvasion
Engine Management and Tuning
19
Sep 10, 2023 04:11 AM
mkhooaah
Jun 3, 2003 10:13 PM
DLOTYPER
Jan 28, 2003 11:19 AM
7rrivera7
Jan 16, 2003 01:51 PM
cool
Apr 2, 2002 09:00 AM
