Need Help Removing Turbo
Old Sep 29, 2005 | 11:38 AM
DC494LS's Avatar
Default Need Help Removing Turbo
Guys, I need some help here. I'm trying to remove my turbo system on my car. What are all of the things that I'm going to need? So far, I just came up with:
1. Intake
2. Header
3. Oil Pan
Is there anything else that I am missing? I need to get the uninstallation all done in one day, so I'm waiting to make sure that I have all the parts that I'm going to need. One thing I learned is that knowledge and great preperations make any work on your car MUCH easier! Thanks ahead of time for the suggestions and the knowlede you guys share with me.
Old Sep 29, 2005 | 11:50 AM
nota-eg's Avatar
Default Re: Need Help Removing Turbo (DC494LS)
-Injectors.
-FMU if you're using one.
-Downpipe needs to be replaced by header/Y pipe.
Old Sep 29, 2005 | 12:41 PM
TurboCoop's Avatar
Default Re: Need Help Removing Turbo (nota-eg)
the big thing is the fuel management, what are you using with the turbo? dont forget to put the oil pressure sender back in its place!! Thats pretty much it other than intake, headers, and oil pan I guess
Old Sep 29, 2005 | 03:02 PM
DC494LS's Avatar
OK! So, other than the things I've already listed, I just need to change out the injectors with the stock ones, remove my FMU, and get a Y pipe to replace the downpipe? So the Y pipe some something that I need additional to the header, correct?
Old Sep 29, 2005 | 03:38 PM
nota-eg's Avatar
Default Re: (DC494LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC494LS &raquo;</TD></TR><TR><TD CLASS="quote">OK! So, other than the things I've already listed, I just need to change out the injectors with the stock ones, remove my FMU, and get a Y pipe to replace the downpipe? So the Y pipe some something that I need additional to the header, correct?</TD></TR></TABLE>
Yes, the Y pipe connects to your manifold. As long as its a stock setup, anyway. I'm not sure how aftermarket headers work.
Old Sep 29, 2005 | 04:19 PM
DC494LS's Avatar
Yeah! I figure if I'm going to pay for an intake, header and exhaust ( since 3" will be too big for a NA setup ) I might as well, just get all aftermarket.
Old Sep 29, 2005 | 05:21 PM
TurboCoop's Avatar
what injectors were you running if you had an FMU???
Old Oct 5, 2005 | 09:29 AM
DC494LS's Avatar
I have 370cc, and that's the reason why I'm removing the FMU. I was told that I can tune it with just the SAFC and the larger injectors.
Old Oct 5, 2005 | 10:16 AM
EJ1 wilcox's Avatar
Here's what I did when I removed my turbo:
- Take off turbo, downpipe, FMIC, and piping
- Plug oil feed with an allen plug and plug oil pan with -10an cap
- Install stock air intake and stock header
- Install stock GSR basemap w/ out boost options etc. (not needed but I did anyways)
That's it!
Later on I replaced the injectors with the stock injectors, desoldered the resistor box, and replaced the chipped ECU with a stocker.
I am going to replace the oil pan with a stock one later on as well.
Old Oct 5, 2005 | 10:36 AM
DC494LS's Avatar
Beautiful! Thank you!
$MIKE$
Dec 8, 2013 12:52 PM
dsturch1
Jun 10, 2010 02:49 PM
sonne_side
Mar 31, 2009 11:40 PM
EKris
May 15, 2007 09:58 PM
ACURACY_VTEC
Aug 13, 2002 11:11 AM
