GSR cams in a b16 head: Good for Turbo?
Old Sep 28, 2005 | 05:46 PM
Toneman14's Avatar
Default GSR cams in a b16 head: Good for Turbo?
I'm going to be picking up a b16 head for an LS/VTEC setup. I have a turbo setup waiting to go on the car too. The head will be ported/polished, multiangle valve job, upgraded spings, retainers, and valves but I havent decided on which cam would be best for a turbo LS/VTEC setup yet. Two sources from two different local shops where I'm located both reccommended GSR cams for a turbo. They said the grind is almost identical to CROWER's turbo cam.
so here's questions......
IS a GSR cam an adaquete cam for turbo? Why or why not? If not, which would be the best for the application.
Other Info: The block will be built as well, with JE pistons 10:1 compression, and eagle rods. If that helps any.
Old Sep 28, 2005 | 05:47 PM
Toneman14's Avatar
I should probably give some turbo specs too.
It's a t3/t4e .57 trim
Old Sep 28, 2005 | 05:55 PM
BoostedJeff's Avatar
Default Re: (Toneman14)
i am running GSR cams in my b16 head. I was told that those cams and adjustable cam gears can yeuild you up to 50 whp over stock geared b16 cams
Old Sep 28, 2005 | 07:22 PM
2quikmotorwerks's Avatar
Default Re: GSR cams in a b16 head: Good for Turbo? (Toneman14)
either one of the cams would be fine for you turbo setup b16 or b18c1
Old Sep 29, 2005 | 03:43 AM
Toneman14's Avatar
Default Re: (BoostedJeff)
I thought you could only use Cam Gears with aftermarket cams??
Old Sep 29, 2005 | 06:39 AM
LostSolVTEC's Avatar
negative,
stock B16 at 10psi i made a little over 230hp 160ish trq
GSR cams and STR cam gears i put down 290hp and 200 trq at 9.5 psi
dyno graph was a lot smoother too (i'll see if i can find them)
Old Sep 30, 2005 | 06:42 AM
Toneman14's Avatar
Default Re: (LostSolVTEC)
yeah please do if you could....what are your cam settings?
Old Sep 30, 2005 | 07:05 AM
turbosi03's Avatar
I'm using GSR's in the b16 head, and AEM cam gears I'm at about 350whp conservative tune cam gears set to zero...
Old Sep 30, 2005 | 08:33 AM
Stock B16 cams at 10psi
GSR cams and STR cam gears at 9.5 psi (not sure about the settings, each set up will be different
Old Sep 30, 2005 | 08:45 AM
LoSt is BlaCk's Avatar
damn the cams and the gears DID make good hp
Old Sep 30, 2005 | 09:40 AM
ghostskinner's Avatar
Default Re: (LoSt is BlaCk)
was that second graph for the same b16
Old Sep 30, 2005 | 12:52 PM
Default Re: (ghostskinner)
yep, both were my car
stock B16, stock intake manifold, stock tb. Only thing changed was the GSR cams and STR gears.
And i switched from a Hondata S200B to Neptune, but i don't know that allowed any more power or not, i doubt it made that much of a difference
Old Sep 30, 2005 | 12:59 PM
SlowB16si's Avatar
LostSol whats your setup?
Damn Im switching my stock b16 cams to ITR's
I knew it made a difference, but not that much
Old Sep 30, 2005 | 06:45 PM
Default Re: (SlowB16si)
Stock B16, GSR cams, STR gears, ProFab intake manifold gasket
InlinePro SS manifold
T3/To4E .57 trim .63 A/R
PWR intercooler
2.5'' piping
3'' DP and exhaust
Tial 38mm WG
RC 550cc injectors
Walbro 255hp intank
Neptune
that's pretty much the basics, if you have any more questions about it shoot me a pm
bb6guy
Aug 22, 2011 03:49 PM
[Ennis_D]
Jun 10, 2009 04:57 PM
Topdawgg
Dec 7, 2005 02:28 AM
Chuji
Oct 31, 2005 05:01 PM
Kamin
Jun 29, 2002 01:42 PM
