using hondata
Old Mar 2, 2002 | 11:37 AM
lsvtechatch's Avatar
Default using hondata
are you able to adjust the rev limiter and vtec crossover by using a labtop or is using the button the only way? i cant seem to set my vtec or my rev limiter correctly and cant figure out the problem. i do exactly as the video and manual say but its not working. any help would be appreciated. thanks
Old Mar 2, 2002 | 05:28 PM
racerxadam's Avatar
Default Re: using hondata (lsvtechatch)
it depends on what ecu you are using. obd-1 and later ecus can set the rev limits on romeditor but i havent' figured out how to do it with obd-0 ecus yet. maybe in the next edition of rom editor. maybe try switching the position of the plugs at the hondata blue box. there is another post floating around where the box was labeled wrong. the clutch and set buttons were labeled backwards.
Old Mar 3, 2002 | 08:30 AM
Default Re: using hondata (racerxadam)
im using a p28 obd 1 ecu in my 90 hatchback
ebpcivicsi1234
Jan 12, 2005 08:31 PM
JoeyBallzSI
Jun 3, 2004 09:53 AM
papa_smurf
Nov 24, 2002 02:56 PM
neumonik
Jul 23, 2002 10:23 PM
