^*^*^*^Tranny Chattering only in 1st???^*^*^*^*
When I put the gear in first, I get this metal on metal vibrating soung, and if I tap down on the shifter, makes a noise as well, but only in first. all the other gears are smooth and make no noise. Is it clutch chatter? Is it a bearing problem? Is the gear grinding? Please need help.
what clutch do you have? act 6 pucks make noise, i know that, and my act SS makes noise with my 7lb flywheel. its not tranny chatter either, its clutch chatter.the disk is bouncing off the flywheel.
eg_b18c
Transmission & Drivetrain
17
Oct 31, 2018 07:24 PM
97dxred
12
Aug 8, 2008 05:28 AM
carsaregood
May 11, 2006 11:14 AM
Touch
Sep 30, 2005 04:41 AM
