Alarm LED Location?
I have a 2002 accord and I am installing the factory security system. The owner's manual shows the LED located on the drivers door, by the lock ****, up by the window. The installation manual for the security system says to put it on the top of the steering column. Is there a "best" location? I assume if I move it from where it will reach, that the LED wires can be extended? I know this is a pretty simple question....just want to make sure. Thanks...
yeah you could extended them. just soilder on some longer wires. also i would put it on the sterring c. or get a led light strip off ebay and mount it on the dash.
on DEI LED's you can take off the red plastic cover and you left with a tiny clear led bulb. The led still blinks red. Drill a small hole and push the led in from behind. Then use hot glue to hold it there. Cleanest led install and when its off you barley notice it.
I agree with MLD211. It doesn't matter where you mount it, it always functions the same. It's all personal preference. I have mine mounted in the A pillar towards the top pointed towards the center of my dash. Looks cool at night or when there's water on my windshield. Good luck.
Nate
Nate
I would recomend mounting it anywhere that is visible from almost anywhere outside of the car . As well as in a spot that can be replaced ( i.e a pop out panel ) . This in case you want to take it out , you wont have a hole in some panel that is millions to replace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlusOne »</TD></TR><TR><TD CLASS="quote">I would recomend mounting it anywhere that is visible from almost anywhere outside of the car . As well as in a spot that can be replaced ( i.e a pop out panel ) . This in case you want to take it out , you wont have a hole in some panel that is millions to replace
</TD></TR></TABLE> Ditto that,
Find the cheapest piece of plastic to replace, [if you had to] and mount it to that, a dummy plug for a switch that you don't have works real good, next best thing is the top piece of the steering column trim, it's highly visible and its a cheap piece of plastic to replace, [relative to other dash or console trim]
94
94
justint
Apr 8, 2006 09:58 PM
deoexmacchina
Audio / Security / Video
Oct 17, 2005 05:28 PM
Undepelo
Aug 19, 2002 09:09 PM
