kill switch...fuelpump
Old Sep 24, 2005 | 04:28 PM
EJ1_203's Avatar
Default kill switch...fuelpump
i keep adding 2 my car i want to protect my investment i already have a viper pager alarm . and the cluth lock club but i am 2 lazy 2 put it on all the time. So i want to add a kill switch for when i go places and i just want a quock lock up
does anyone kno which wire i should go 4.
from the ECU 0r the fuel pump itself if so which wire should i go for?
95 honda civic EX! stock fuel pump
thankz guyz
Old Sep 25, 2005 | 01:01 PM
97Soler's Avatar
Default Re: kill switch...fuelpump (eg94civic)
Definately add the kill switch, ecu is easier in my opinion. I ran multiple kills in my sol after the first botched theft attemppt, but here is my opinion. Use that clutch club as a deterrent, because they might not be able to steal your car due to the kill switch, but that clutch club will make it so they will not attempt to jam your ignition and run you $300 for a new ignition assembly. I learned that the hard way. Hope that helps.
Old Sep 25, 2005 | 01:59 PM
93Sivic's Avatar
my friend ran his from the fuel pump with a relay and it hasnt given him probs.....
Old Sep 25, 2005 | 02:05 PM
Kyles ej1's Avatar
i have an autolock and it seriously takes me 15 seconds to put on and that includes grabbing it from the back seat.....are you really that lazy?
Old Sep 25, 2005 | 02:06 PM
JDMlyfestyle's Avatar
I did a direct to the fuel pump wiring. also cut the stock wire at least 2 feet back. cause if you just cut and splice into it. thn its not hard to break that splice and just connect the stock wire to the fuel pump.
Old Sep 25, 2005 | 04:01 PM
EJ1_203's Avatar
Default Re: (JDMlyfestyle)
THANKS GUYS..
fuel pump
but is there a specific wire which i need 2 splice into or does it matter?
because i dont wanna splice into just any wire .
ecu
which plug is the pin in and what color combo is it?
thankz guys
Old Sep 25, 2005 | 04:03 PM
Kyles ej1's Avatar
Default Re: (eg94civic)
**** yea you need to splice the right wire!! i think for the fuel pump its green with yellow stripe
edit- yellow with green*
Old Sep 25, 2005 | 04:26 PM
ThatsMyEG's Avatar
Default Re: (93ejay1)
You shouldnt mod your car if your to lazy to protect it..
I use 2 kill switches, a alarm and a club everywhere i go..
Old Sep 25, 2005 | 04:47 PM
A multi meter is your friend. unplug the fuel pump or move some of the insulation and test the line to see whats getting voltage. if u move some of the insulation off the wires you should place some electrical tape to protect the wires.
Old Sep 25, 2005 | 09:02 PM
EJ1_203's Avatar
thanks jdm and thatsmyeg i just want something a little more .
thankz guyz!
Old Sep 25, 2005 | 09:11 PM
pdiggitydogg's Avatar
http://www.hstuners.com/forums...24389
Old Sep 25, 2005 | 09:12 PM
1995Ex_Sedan's Avatar
You're welcome.
http://www.courtlukens.com/Tech/cutoff_switch.htm
Old Sep 25, 2005 | 09:16 PM
the link I provided is a safer, better how-to that I setup with help of ee_chris
Old Sep 25, 2005 | 09:23 PM
RudeBwaiSi's Avatar
Default Re: (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">You shouldnt mod your car if your to lazy to protect it..
I use 2 kill switches, a alarm and a club everywhere i go.. </TD></TR></TABLE>
Same here. . .minus the club.
Old Feb 6, 2006 | 09:32 PM
EJ1_203's Avatar
Default Re: (RudeBwaiSi)
Old Feb 6, 2006 | 11:46 PM
Kangolbrand's Avatar
good info/directions.
98y8
May 5, 2010 12:06 PM
hybridmoments
Audio / Security / Video
Jan 24, 2007 02:19 PM
EJ8 GSR-T
Dec 25, 2006 06:46 PM
hatchinprogress
38
Mar 19, 2006 06:39 PM
oMek
Jul 27, 2003 07:00 AM
