kill switch...fuelpump
i keep adding 2 my car i want to protect my investment i already have a viper pager alarm . and the cluth lock club but i am 2 lazy 2 put it on all the time. So i want to add a kill switch for when i go places and i just want a quock lock up
does anyone kno which wire i should go 4.
from the ECU 0r the fuel pump itself if so which wire should i go for?
95 honda civic EX! stock fuel pump
thankz guyz
thankz guyz
Re: kill switch...fuelpump (eg94civic)
Definately add the kill switch, ecu is easier in my opinion. I ran multiple kills in my sol after the first botched theft attemppt, but here is my opinion. Use that clutch club as a deterrent, because they might not be able to steal your car due to the kill switch, but that clutch club will make it so they will not attempt to jam your ignition and run you $300 for a new ignition assembly. I learned that the hard way. Hope that helps.
i have an autolock and it seriously takes me 15 seconds to put on and that includes grabbing it from the back seat.....are you really that lazy?
I did a direct to the fuel pump wiring. also cut the stock wire at least 2 feet back. cause if you just cut and splice into it. thn its not hard to break that splice and just connect the stock wire to the fuel pump.
Re: (JDMlyfestyle)
THANKS GUYS..
fuel pump
but is there a specific wire which i need 2 splice into or does it matter?
because i dont wanna splice into just any wire .
ecu
which plug is the pin in and what color combo is it?
thankz guys
fuel pump
ecu
thankz guys
A multi meter is your friend. unplug the fuel pump or move some of the insulation and test the line to see whats getting voltage. if u move some of the insulation off the wires you should place some electrical tape to protect the wires.
Re: (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG »</TD></TR><TR><TD CLASS="quote">You shouldnt mod your car if your to lazy to protect it..
I use 2 kill switches, a alarm and a club everywhere i go.. </TD></TR></TABLE>
Same here. . .minus the club.
hybridmoments
Audio / Security / Video
01-24-2007 02:19 PM
hatchinprogress
38
03-19-2006 06:39 PM
