96-00 Civic AFTERMARKET EXHAUST system help....with catalytic converter....
Old Sep 23, 2005 | 09:42 PM
Hatch It's Avatar
Default 96-00 Civic AFTERMARKET EXHAUST system help....with catalytic converter....
So i may be picking up a 96 DX civic hatch this month. I heard that the exhaust is a bit different in terms of the cat location.
Here is a pic:
If i bought an aftermarket ccat-back system and some aftermarket headers that do not have the cat in them, would i need like a factory EX/Si cat? or how would that work since with aftermarket headers having the "cat delete" and the CAT-BACK exhaust not connecting to anything....
if you get what im saying..?
Thanks for the help.
Old Sep 23, 2005 | 10:11 PM
rallystyle's Avatar
Default Re: 96-00 Civic AFTERMARKET EXHAUST system help....with catalytic converter.... (Hatch It)
if the cat back is for the hatch it will just bolt up
Old Sep 23, 2005 | 10:16 PM
EL Vap133's Avatar
Yes, you can use an EX or Si cat, that's what I did in my DX.
Old Sep 23, 2005 | 10:17 PM
Hatch It's Avatar
Default Re: 96-00 Civic AFTERMARKET EXHAUST system help....with catalytic converter.... (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can use an EX or Si cat, that's what I did in my DX. </TD></TR></TABLE>
exactly the answer i needed its for a DX too thanks bro
Old Sep 23, 2005 | 10:20 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It &raquo;</TD></TR><TR><TD CLASS="quote">
exactly the answer i needed its for a DX too thanks bro</TD></TR></TABLE>
You just need to extend the o2 sesnsor wires and you're set.
Old Sep 23, 2005 | 10:21 PM
Hatch It's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You just need to extend the o2 sesnsor wires and you're set. </TD></TR></TABLE>
is that hard? how would i go about that?
Old Sep 23, 2005 | 10:23 PM
EL Vap133's Avatar
https://honda-tech.com/zerothread?id=1374845
Old Sep 23, 2005 | 10:52 PM
96CivicBoostCoupe's Avatar
you need to get a cat fron an ex.si ir go on ebay and get an OBX cat because there will be a 1 foot gap of where its supposed be. you will also have to extend both o2s sensons wires cause the cat on a dx is up front and ex/si is under the car and the 02s go before and after the cat in those models as well
Old Sep 23, 2005 | 11:12 PM
Hatch It's Avatar
Default Re: 96-00 Civic AFTERMARKET EXHAUST system help....with catalytic converter.... (96CivicBoostCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe &raquo;</TD></TR><TR><TD CLASS="quote">you need to get a cat fron an ex.si ir go on ebay and get an OBX cat because there will be a 1 foot gap of where its supposed be. you will also have to extend both o2s sensons wires cause the cat on a dx is up front and ex/si is under the car and the 02s go before and after the cat in those models as well</TD></TR></TABLE>
Thansk for the help
walsh22
18
Mar 14, 2007 08:09 PM
mini-e
Aug 26, 2006 11:16 AM
shredder22
11
Jun 7, 2006 07:33 PM
Greg123
27
Dec 29, 2003 02:46 PM
RickChew
Feb 17, 2003 12:03 PM
