5 lug conversion question
Old Sep 23, 2005 | 02:56 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default 5 lug conversion question
I know there is a difference in 5 lug conversion for the front axles.
SO here it goes
I purchased a 5 lug off a USDM type R
SO that means my axles are 32mm which means I can run oem US integra axles correct?
The JDM 5 lug is 36mm correct?
Also the guy cut the e brake cables, will Da integra cables work or I HAVE to get DEL SOL VTEC cables
this is for a 93 cx hatch
Old Sep 23, 2005 | 06:54 PM
hatchi's Avatar
Default Re: 5 lug conversion question (MugenHonda)
i would get 94-00 integra cables. You can try and see if the DA might work. yes you will need 94-00 integra axles
Old Sep 23, 2005 | 07:26 PM
clm's Avatar
clm
Default Re: 5 lug conversion question (hatchi)
If you have a D-series your stock axles should slide right in because they have a 32mm spline like the USDM ITR.
From what I recall reading you want e-brake cables for the "style" car (in your case a hatch) that came with rear disc brakes which would mean a '92-'95 Si; although, DC cables are supposed to work with some tweaking. That's what I bought but I haven't done the GSR brake conversion on my '92 CX yet.
Old Sep 23, 2005 | 09:15 PM
FIGARILA's Avatar
i have da teg cables on my 93 hatch works fine with me.
Old Sep 23, 2005 | 09:26 PM
ErrDizzle's Avatar
Stock axles should fit and any rear disk cable civic or integra should work
Old Sep 23, 2005 | 10:20 PM
sockvtec's Avatar
Default Re: 5 lug conversion question (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote">If you have a D-series your stock axles should slide right in because they have a 32mm spline like the USDM ITR.
From what I recall reading you want e-brake cables for the "style" car (in your case a hatch) that came with rear disc brakes which would mean a '92-'95 Si; although, DC cables are supposed to work with some tweaking. That's what I bought but I haven't done the GSR brake conversion on my '92 CX yet.</TD></TR></TABLE>
i did a DA front setup swap and it turned out bad lol, so i figured out the hard way DA knucles dont work right
mysterysktr7
Dec 14, 2008 10:17 PM
BMRALR
20
Oct 13, 2007 06:57 AM
midnightdarknes5
May 8, 2003 06:05 PM
