Is it the VSS?
My speedo moves around randomly and most people would say it's the VSS. But if the speedo is moving around even at idle or even when I just turn the accessories on (car is off).... could it still be teh VSS or does it sound liek somethingelse, like say the gauge cluster??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote">check the connections on the top of your VSS, sometimes the wires becomes corroded or loose</TD></TR></TABLE>
Doubtful. The most likely culprit is bad circuitry and/or solder on the back of the gauge cluster. This is a very common problem in "EG" chassis Civics and has happened to almost all of the ones in my family. Get a new cluster and you're set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote">well, wouldnt hurt to check both
Agreed
</TD></TR></TABLE>Agreed
check your in car fuses
my ek did something like this and it was caused by some crazy fuse in the in car fuse panel.
I want to say it was the alternator fuse but im not 100%. It was a very odd fuse to be blown, i went thru them 1 by 1...
that hapend to me in my eg when i accelerate hard or go over bumps my spedo needle would shake around. it turned out to be the connector to the vss was loose i just tighten it and it went away. and i never heard of the cluster beign the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Doubtful. The most likely culprit is bad circuitry and/or solder on the back of the gauge cluster. This is a very common problem in "EG" chassis Civics and has happened to almost all of the ones in my family. Get a new cluster and you're set.</TD></TR></TABLE>
Having sold 15-20 VSS, the number one issue is a dirty connection at the tranny. Only one VSS was really bad.
