Is it the VSS?
Old 09-21-2005, 12:52 PM
n-line4's Avatar
Default Is it the VSS?
My speedo moves around randomly and most people would say it's the VSS. But if the speedo is moving around even at idle or even when I just turn the accessories on (car is off).... could it still be teh VSS or does it sound liek somethingelse, like say the gauge cluster??
Old 09-21-2005, 03:16 PM
Shaun's Avatar
check the connections on the top of your VSS, sometimes the wires becomes corroded or loose
Old 09-21-2005, 03:27 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">check the connections on the top of your VSS, sometimes the wires becomes corroded or loose</TD></TR></TABLE>
Doubtful. The most likely culprit is bad circuitry and/or solder on the back of the gauge cluster. This is a very common problem in "EG" chassis Civics and has happened to almost all of the ones in my family. Get a new cluster and you're set.
Old 09-21-2005, 03:30 PM
Shaun's Avatar
well, wouldnt hurt to check both
Old 09-21-2005, 03:33 PM
Unceasing Measure
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">well, wouldnt hurt to check both </TD></TR></TABLE>
Agreed
Old 09-21-2005, 03:45 PM
turbotime's Avatar
check your in car fuses
my ek did something like this and it was caused by some crazy fuse in the in car fuse panel.
I want to say it was the alternator fuse but im not 100%. It was a very odd fuse to be blown, i went thru them 1 by 1...
Old 09-21-2005, 05:39 PM
o5mar1's Avatar
that hapend to me in my eg when i accelerate hard or go over bumps my spedo needle would shake around. it turned out to be the connector to the vss was loose i just tighten it and it went away. and i never heard of the cluster beign the problem.
Old 09-22-2005, 01:50 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Doubtful. The most likely culprit is bad circuitry and/or solder on the back of the gauge cluster. This is a very common problem in "EG" chassis Civics and has happened to almost all of the ones in my family. Get a new cluster and you're set.</TD></TR></TABLE>
Having sold 15-20 VSS, the number one issue is a dirty connection at the tranny. Only one VSS was really bad.
THC07
02-15-2008 05:31 PM
Mires
05-13-2005 07:44 AM
itr1235
06-02-2004 08:39 PM
neXus dc4
05-07-2004 07:17 AM
PA MATT
03-29-2004 11:22 AM
Quick Reply: Is it the VSS?
