BoUNciNg speedometer
Old Mar 29, 2004 | 08:41 AM
PA MATT's Avatar
Default BoUNciNg speedometer
I recently removed my gauge cluster to put in amber bulbs. I put it back in and now the speedometer goes crazy and the needle jumps to all different speeds. what could the problem be?i know the speedo cable is in all the way. any help would be appreciated. thanks alot
Old Mar 29, 2004 | 10:22 AM
Chronic_SMOKE's Avatar
Default Re: BoUNciNg speedometer (ebpG2)
take off your distributor cap and tighten down all the screws you see, it could be a loose connection
Old Mar 29, 2004 | 10:38 AM
xplanetearth420x's Avatar
Default Re: BoUNciNg speedometer (Chronic_SMOKE)
check all the wires behind ur gauge cluster make sure you didnt upset anything
Old Mar 29, 2004 | 10:55 AM
PA MATT's Avatar
Default Re: BoUNciNg speedometer (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronic_SMOKE &raquo;</TD></TR><TR><TD CLASS="quote">take off your distributor cap and tighten down all the screws you see, it could be a loose connection</TD></TR></TABLE>
thanks for the idea, but it was workin fine before i took out the cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">check all the wires behind ur gauge cluster make sure you didnt upset anything</TD></TR></TABLE>
i checked when i put it in, but im gonna check again and lube up the speedo cable. its a 91 and has the speedo cable, i believe the newer ones are vss so dont have speedo cable. Hopefully this works, but any other suggestions are appreciated especially concerning lubing the speedo cable
Old Mar 29, 2004 | 11:10 AM
emissionsux's Avatar
Might need to grease the speedo cable.
Old Mar 29, 2004 | 11:20 AM
PA MATT's Avatar
Default Re: BoUNciNg speedometer (emissionsux)
with just any grease?i was told graphite lube or something
Old Mar 29, 2004 | 11:22 AM
I think dielectric grease
tommy.
12
Aug 29, 2006 05:27 PM
Pooby88
Jul 3, 2006 06:26 PM
stemiched
19
May 2, 2006 11:34 AM
n-line4
Sep 22, 2005 01:50 AM
Mires
May 13, 2005 07:44 AM
