check engine code 22
Can anyone please help me out. i have a 1994 civic with a b16 everything runs alright but my vtec is not working. i am throwing a check engine code 22 wich means oil pressure switch problem. the oil pressure switch in the car is good because i have tried different ones. i tried running a direct wire from the oil pressure switch to my ecu and when i started my car it made it idol like the timing was off really bad. i do no know how to fix this code and get my vtec back so will someone please help me out
thanks
thanks
i know it is an oil pressure switch, but my oil pressure switch is perfect on my car, so that is not the problem. for some reason it is still reading the code even though the switch works and everything.
ComeOnKip
15
Feb 18, 2013 03:35 AM
drudy
Aug 7, 2005 05:59 AM
