Help Please - Rotor/ wheel studs wobble- How to fix???
Old Sep 16, 2005 | 01:02 AM
tur3oDC4's Avatar
Default Help Please - Rotor/ wheel studs wobble- How to fix???
Hey, i noticed my rotor and wheel studs all move around and wobble a little bit. The brake dust shield stays in one place though. If i hold the rotor, or the wheel when its on, theres a significant amount of play. Can anyone guide me in the right direction here, im getting my car tuned tomorow- Is it ok to drive on it like this? I already drove like 100 miles with it like that?? ?
thanks
Old Sep 16, 2005 | 02:18 AM
97tegGS's Avatar
Check to make sure your lugnuts are torqued.
I would also check your ball joints
Old Sep 16, 2005 | 05:20 AM
Sam92Teg's Avatar
Default Re: (97tegGS)
Are the two screws that hold the rotor in place still there? When some people swap rotors they leave the 2 rotor screws off, which leaves only the lug nuts to hold the rotor in place. When you remove the wheel, the rotor will have play untill you mount the wheel back.
If you do have the rotor screws in place, then maybe your wheel bearings are shot.
Old Sep 16, 2005 | 05:27 AM
Racermech's Avatar
Default Re: (Sam92Teg)
Thoses screws dont do a anything once the wheel is on and tight. THey are used at the fatory to keep everything from moving around. A lot of car dont come with any sort of screw.
If the lug nuts are tight, but you can wobble the wheel around check all of your suspension, espically the lower ball joints as stated above. Make sure the pins are in place to keep the king nut from backing off.
Also check the wheel bearings. If the bearing has gone the you might be able to see some grease around the bearing.
Old Sep 16, 2005 | 11:26 AM
tur3oDC4's Avatar
Default Re: (Racermech)
Thanks guys, i think its gotta be the wheel bearing , how do you get it out? Is it safe to drive on for a little bit, i kinda gotta go somewhere today? thanks
googoodc
May 13, 2009 06:03 AM
sickofitall1113
Oct 10, 2006 09:39 PM
CHONCH
22
Dec 1, 2003 09:21 PM
DEVIN22CBR
Jun 6, 2003 08:07 PM
-iLLuZioN-B18C1
Jun 16, 2002 04:23 PM
