is this a problem
Old Sep 15, 2005 | 06:19 AM
92civichatch1's Avatar
Default is this a problem
if i can get an LS motor from a 1998 LS can i use the rest of the swap from a 1995 LS and have it work. the reason im asking is because the 1998 is an automatic and i obviously want standard. I know there will probably be some wiring but i wanna make sure that the rest of the swap i.e. trans, mounts, shifter, axels, ecu... work.
Ive got a 1992 hatchback CX
Old Sep 15, 2005 | 06:20 AM
ralphie14's Avatar
Default Re: is this a problem (92civichatch1)
yes even though the motor will be a 98 you can use the tranny/flywheel and everything from the 94.
Old Sep 15, 2005 | 06:25 AM
veggiemaster's Avatar
You can swap the motor no problem, but you might run into some OBD2 snags, such as injectors/clips
Old Sep 15, 2005 | 06:27 AM
nota-eg's Avatar
Default Re: is this a problem (ralphie14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 &raquo;</TD></TR><TR><TD CLASS="quote">yes even though the motor will be a 98 you can use the tranny/flywheel and everything from the 94.</TD></TR></TABLE>
He said 95
But as ralphie said, you can use just about anything from 94-98 as it's all interchangeable.
edit: Nevermind. What years did the integra go from OBDI to OBDII?
JDM-EJ1's Avatar
Old Sep 15, 2005 | 06:30 AM
Default Re: is this a problem (JDM-EJ1)
thanks alot guys....what kind of wiring is going to be involved. my car now is OBD1 and the motor is obviously OBD2 and the swap is OBD1 thanks again
Old Sep 15, 2005 | 06:46 AM
nota-eg's Avatar
I think you're going to need an OBDI to OBDII conversion harness and an OBDII ECU, or a chipped OBDI ecu.
It's basically doing an OBDII swap because the motor is OBDII. The rest of the stuff is just nuts and bolts.
Old Sep 15, 2005 | 06:47 AM
should i use the obd1 ecu or the obd2 ecu
with the obd2 ecu (id have to change it from auto to standard)
Old Sep 15, 2005 | 06:50 AM
nota-eg's Avatar
If you have access to the OBDI I would take that and get it chipped to run an OBDII motor. That way you don't have to buy a conversion harness.
I think OBDII motors have a few more sensors that OBDI motors don't have.
Old Sep 15, 2005 | 06:54 AM
Default Re: is this a problem (nota-eg)
How do i get it chipped?
Old Sep 15, 2005 | 06:55 AM
and again how much wiring is involved?
Old Sep 15, 2005 | 06:57 AM
nota-eg's Avatar
I don't know where you could get it chipped. PM Kenji, he does ECU chipping.
It might be easier to just convert to OBDII. You'd just need the wiring harness from the 98 and an OBD1 to OBD2 conversion harness.
Old Sep 15, 2005 | 07:01 AM
do you know where i could get a conversion harness? and what exactly is a conversion harness?
Well from what you said before i could either do this obd1 to obd2 conversion or i could just chip my obd1 ecu?
Old Sep 15, 2005 | 07:13 AM
could someone just give me a step by step obd1 to obd2 swap please?
Old Sep 15, 2005 | 07:21 AM
ok this is getting more complicated than it needs to be. id like to stay obd1 since my car and everythin but the motor is going to be obd1. i dont need to worry about inspection. so what do i need to do to keep this car obd1 with an obd2 motor?
Old Sep 15, 2005 | 07:58 AM
If I ripped out the body harness from a 1998 integra Ls, used the engine harness
and the motor( again the trans is automatic so it is useless to me) would all that
plug into everything else in my 1992 hatchback and work? again the big hurdle is
the obd1 to obd2 conversion i dont have any experience with swappin the obds so
please help me!!!!!!!!!!!!
Old Sep 16, 2005 | 05:27 AM
ralphie14's Avatar
Dude settle down and use the search function you will get more answers that way.
SOHC_4dr
Jun 19, 2008 11:36 AM
Kingkoopa20
10
Feb 16, 2008 12:24 PM
lee's ej8
Dec 19, 2006 05:04 AM
JnyStylz
12
Dec 28, 2004 10:48 AM
Kaneo
Mar 28, 2004 06:01 PM
