WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR
Whats the difference between 92-93 ls motor and a 94+ ls motor
i have a 95 eg, I think that im leaning twards doing an ls swap. then turbo down the road instead of turbo charging my 1.5L. My question is, Is there a major performance or instalation difference between the 92-93 ls motor and the 94+ ls motor?? either way i plan to use a 94+ B series tranny. I would greatly appreciate all of your help. Thanks
Modified by JnyStylz at 12:02 PM 12/28/2004
be professional
Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (JnyStylz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JnyStylz »</TD></TR><TR><TD CLASS="quote">My question is, Is there a major performance or instalation difference between the 92-93 ls motor and the 94+ ls motor??</TD></TR></TABLE>
Not really. Mounts are the only significant difference.
first of all, dont make titles in all caps, that is frowned upon. And for the motor i dont think there is much of a difference, just make sure you get a b18b not b18a
be professional
Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">just make sure you get a b18b not b18a</TD></TR></TABLE>
'92-93 engines are stamped B18A1. '94-01 engines are stamped B18B1.
Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (Targa250R)
thats what i thought, from what i hear the b18b is a better motor...
Re: Whats the difference between 92-93 ls motor and a 94+ ls motor (JnyStylz)
Sorry about the CAPS. So do I need a mount kit to put the 92-93 ls motor in my 95 eg
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">thats what i thought, from what i hear the b18b is a better motor...</TD></TR></TABLE>
The '92-93 B18A1 is pretty much identical to the B18B1.
The '90-91 B18A1 is the one with slight differences.
I'm not 100% positive but...
'90-'91 B18A OBD0 rated at ~130hp
'92-'93 B18A OBDI rated at ~140hp (I think it had a longer duration intake cam)
'94-'95 B18B same as '92-'93, but with a better intake manifold
'96+ B18B OBDII and I think It came with knock sensing
someone correct me if I'm wrong
overrated.
Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (squirrel)
if you get a 92-93, make sure you get the driver's side mount bracket from a 94+ motor.
Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (OnePointFive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointFive »</TD></TR><TR><TD CLASS="quote">if you get a 92-93, make sure you get the driver's side mount bracket from a 94+ motor.</TD></TR></TABLE>
is that the only thing that i need in order to do the swap
Fighterinsnatch
09-22-2008 08:44 AM
WhoNeedsBoost
04-24-2002 10:29 AM
