D16Y8 Backfiring
Old Sep 3, 2005 | 07:55 PM
5lugSlug's Avatar
Default D16Y8 Backfiring
I have a 1998 Honda Civic EX and it backfires like a bitch (randomly) when in first gear. It does it mosly when its in VTEC, getting ready to shift into 2nd.
Keep in mind its an automatic (if it effects anything)
What needs to be done to fix this problem?
Old Sep 4, 2005 | 10:40 AM
5lugSlug's Avatar
bump
Old Sep 4, 2005 | 10:47 AM
underb00steg6's Avatar
Default Re: D16Y8 Backfiring (waterboy)
timing ? might be a little off. and looks like you running really rich
Old Sep 4, 2005 | 12:21 PM
blaster834's Avatar
yea most likey timing. when was the last time you replaced the plugs
Old Sep 4, 2005 | 02:11 PM
5lugSlug's Avatar
i replaced the whole ignotion setup (distributor, wires, plugs, coil) like amonth ago.
Old Sep 5, 2005 | 07:39 AM
5lugSlug's Avatar
how do i fix the timing... im tired of hearing this gay sound
Old Sep 5, 2005 | 06:43 PM
94Delsol d15's Avatar
Default Re: (waterboy)
I take it you are back firing out the exhaust? not the intake? What type of fuel sytem do you have? oversized injectors?
As far as timing, you will need a timing light and a wrnch to loosen the distributor. You will need to get a service manual if you dont have one. Read the proceedure in the manual its pretty straight forward. You will need to stop the ECU from Advancing timing, there should be a plug located under the dash possibly that you will ground the pins together to do this. Then use a timing light to see where the timing currently is at with the marks on the crankpulley. Adjust the dist to get the timing where it should be.
Sounds confusing doesnt it? its not its easy just make sure your car is warmed up and idling below 900RPM
Terry
Old Sep 5, 2005 | 08:34 PM
neutron91's Avatar
Default Re: (94Delsol d15)
do you have a cat on the car?
Old Sep 6, 2005 | 08:22 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waterboy &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1998 Honda Civic EX </TD></TR></TABLE>
Love your car do you????
Old Sep 6, 2005 | 06:15 PM
5lugSlug's Avatar
its an axle back exhaust
i have injen short ram intake
i have stock fuel setup
Old Sep 6, 2005 | 06:59 PM
Stripped Honda's Avatar
99-0104
open up the distributor and check the rotor make sure it is still ok and nothing is loose inside the dizzy
mwwtx
Feb 10, 2010 04:26 PM
maddog20
Jan 12, 2008 07:05 PM
92EG8
Nov 21, 2006 09:01 AM
dunkd
Jun 19, 2006 10:42 AM
