Compression test results.
here is a link to my old post https://honda-tech.com/zerothread?id=1325078 I keep changing topics so i decided to start a new post. Ok i had 2 check engine lights before i went home last weekend. I took off my vafc and now i dont have any. I was throwing a 21 and 22 with the vafc on. 21 and 22 are both vtec codes. After i took the vafc off i finally got to do a compression check. Im burning a lot of oil and plan on putting in ctr pistons this winter. Here are the results.
Cyc1 = 177
Cyc2 = 174
Cyc3 = 176
Cyc4 = 180
I was told thats pretty low for a b16a2. What do you guys think?
Cyc1 = 177
Cyc2 = 174
Cyc3 = 176
Cyc4 = 180
Re: Compression test results. (Dirtfall)
that does seem low but it is consistant so i wouldnt be too worried. how long did u crank it for? are you sure you did it right?
Re: Compression test results. (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">that does seem low but it is consistant so i wouldnt be too worried. how long did u crank it for? are you sure you did it right?</TD></TR></TABLE>
What should it be??
What should it be??
As long as they are within 20% of each other you should be ok. Did you do the test with the motor hot or cold? This will make a difference in the results.
Re: Compression test results. (ramtyper19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramtyper19 »</TD></TR><TR><TD CLASS="quote">220-230 psi is the norm for b16s
Yeah, you your rings might be going bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramtyper19 »</TD></TR><TR><TD CLASS="quote">What should it be??</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramtyper19 »</TD></TR><TR><TD CLASS="quote">220-230 psi is the norm for b16s
lemme guess...did you search?
but yea thats right, my d16 was at 190
its 210-230:-D
i get 210-215 straight across
jdm b16a sir2
its 210-230:-D
jdm b16a sir2
Re: Compression test results. (komat)
the motor was cold when the test was done. I didnt do it i watch under the hood while my friend did it. I had him crank it till the gauge didnt go up anymore. Prolly about 7 cranks. The only thing im not sure is if he did it at WOT or not.
