Oil Pressure sender...stock AND aftermarket?
Do I need the stock oil pressure sender AND the Defi one that comes with the Defi Oil Pres. gauge? Do I need to use the stock one and get an extra brass T fitting for my oil feed line?
You GUESS the defi is more accurate? WTF
Remove the stock oil pressure sensor and replace with the aftermarket unit. Leave the stock one dangling. It wont light the oil light unplugged. If you want both plugged in your going to need to buy one of those T fittings but running both is redundant.
