I Have No O2 Bung
i dont have a O2 bung on my 99 LS exhasut manifold...guessing it was on the cat instead...dont really wanna get another cat..so which exhaust can i use that have a O2 bung already on it? do i have to extend the wires for the O2? i'm using a obd1 integra harness instead of the civic harness...this motor is going into 95 coupe...thanks
only thing worried about...i would do that...its just that the oem bungs are deep inside the header...as for weld ons they sit on top of the head...just wondering if that would throw off the readings
Hey again the wire on the harnees should reeach the cat if the bung is in the front. On the 94-96 LS mani, which is what you want to find if you dont go aftermarket, the bung is located like 2 inch up from where the cat and mani bolt together.
it's nowhere to be found?? did you check the back side of the exhaust manifold? because I was working on d series for a while, and was used to the sensor being on the front, but when i got my LS, it was on the back, before the cat.
redpeppers
28
Sep 24, 2005 06:17 PM
u2civic1
Aug 9, 2003 12:27 PM
