tubo and o2 senors
tubo and o2 senors
what do you do about your o2 sensors when installing a turbo kit? ( he kit does not have holes for the primary or secondary 02 sensor) Will an o2 simulator work for the primary and secondary?
Re: tubo and o2 senors (silver4)
you need the primary O2, period. Get an O2 bung for it, weld it in, then screw the O2 in that. As for the secondary, you can do the same thing or get an O2 sim... Im guessing you removed the cat. conv. if your askign where the 2nd one is supposed to go...
