Secondary O2 Sensor
Old Mar 28, 2003 | 09:23 PM
1bar's Avatar
Default Secondary O2 Sensor
Right now im runing open downpipe, which only has one o2 bung. If not hooking up my second o2 will that result me throwing codes? Will this hurt performance? Is there any way around this without converting to obd1. My 3 inch catback should be here in the next couple weeks but wanted a solution before then.
Old Mar 28, 2003 | 09:35 PM
1bar's Avatar
Default Re: Secondary O2 Sensor (1bar)
damn this board moves fast!
Old Mar 29, 2003 | 02:29 AM
zip's Avatar
zip
Right now im runing open downpipe, which only has one o2 bung. If not hooking up my second o2 will that result me throwing codes? ext couple weeks but wanted a solution before then.
Use an O2SIM to eliminate any codes when eliminating the catalytic converter.
Available from http://www.importparts.com or http://www.lakeeffectperformance.com
Old Mar 29, 2003 | 05:16 AM
1bar's Avatar
Default Re: Secondary O2 Sensor (zip)
does wraping the o2 in tin foil actually do anything? i read about it somewhere lol. I wish the archives where up.
Old Mar 29, 2003 | 06:14 AM
boostaholic's Avatar
It'll throw a code for the secondary O2, but it won't affect your perfromance.
Old Mar 29, 2003 | 09:05 AM
T25 civic's Avatar
Default Re: Secondary O2 Sensor (boostaholic)
I have no cat, and I'm not throwing any codes. When you put the exhaust back on just weld the bung anywhere in there and put it back in like normal.
Nick
s2k drifter
Mar 30, 2005 01:11 PM
john d
Nov 15, 2004 01:11 PM
5thgencivic
Sep 10, 2003 01:54 PM
speed
Nov 19, 2002 04:28 PM
Qwikrex
Jul 31, 2002 09:53 PM
