Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny?
Old Aug 26, 2005 | 08:28 AM
I Eat Glue's Avatar
Default Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny?
Like stated in the title says Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? its going into a 93 civic ex coupe, if so can i still use the same ECU.
thanks in advance
Old Aug 26, 2005 | 11:20 AM
I Eat Glue's Avatar
Default Re: Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? (JDMspongebob)
ne one
Old Aug 26, 2005 | 11:22 AM
DJ_SaNdOz's Avatar
it's a d series tranny & motor, so it should work fine.
Old Aug 26, 2005 | 12:02 PM
I Eat Glue's Avatar
Default Re: Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? (DJ_SaNdOz)
thanks , as for the ecu what would i use?
FalkenSiR's Avatar
Some people say it does bolt on, some people say it doesn't. Flip a coin
As for the ECU, you will throw a few codes. (VTEC-related) It's not going to run the best, but it will run.
Old Aug 26, 2005 | 12:09 PM
DJ_SaNdOz's Avatar
Default Re: Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? (fast88std)
an auto LS ECU or an auto P06 should work....a little tuning would help them, but it woudl work just fine I'd think.....
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">an auto LS ECU or an auto P06 should work....a little tuning would help them, but it woudl work just fine I'd think.....</TD></TR></TABLE>Yep, hes right. forgot about the LS ecu.
Old Aug 26, 2005 | 04:01 PM
I Eat Glue's Avatar
Thanks, my brother is looking for a new motor for his fiance (hence the Auto) i hinted at this and i seems like a good idea and it different to pop the hood and see that....also its cheap
4thgenhothatch
Sep 19, 2006 10:45 PM
crxkane
Sep 19, 2005 12:58 PM
99sonicbluegsr
Mar 28, 2005 05:01 PM
saucycivic
24
Jun 26, 2001 07:02 AM
saucycivic
Jun 14, 2001 09:03 PM
