The link in Faq on pre turbo engine builds Is not working
Old Aug 26, 2005 | 05:01 AM
Powerforcheap's Avatar
Default The link in Faq on pre turbo engine builds Is not working
Can anyone find it again or summarize what are good things to do before turboing your engine to allow it to be more reliable/make more power. So far I was going to replace the rods,valves,valve springs, head studs, and I was going to put in a golden eagle block gaurd. Anything I don;t need anything else i should have?
Old Aug 26, 2005 | 05:10 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: The link in Faq on pre turbo engine builds Is not working (Powerforcheap)
Get it sleeved, best thing you can do
Also, drop compression to as close to 8.5:1 as possible
Old Aug 26, 2005 | 07:37 AM
vaporboy12's Avatar
Default Re: The link in Faq on pre turbo engine builds Is not working (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">Get it sleeved, best thing you can do
Also, drop compression to as close to 8.5:1 as possible</TD></TR></TABLE>
listen to the first thing the guy said not the second
cheap way just throw some pistons and rods in the block and get headstuds.
you can run 10:1 compression if you want just find a good tuner
Old Aug 26, 2005 | 09:20 AM
97turbols's Avatar
Are you looking for this link?
http://forums.evans-tuning.com...build
Old Aug 26, 2005 | 10:42 AM
Rory Breaker's Avatar
Fixed. Thanks for the heads up. And thanks to Jeff for a great writeup.
Handel Spencer
K Series
Jun 5, 2019 02:40 PM
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
lsturbo*
Sep 16, 2006 05:24 PM
12secLSvtec
Jun 29, 2004 02:35 PM
Arch-Angel
Jul 11, 2003 12:56 AM
