Shifter stuck
there is a solenoid that is wired to the brake pedal that releases the shifter when the ignition is in 'run' and the brake pedal is depressed. its on the front of the shifter. if you take the console off, you'll see it. check it and the wiring, and make sure your brake lights work. if the stoplight switch went out and the solenoid doesnt know you are pushing the brake, then it wont release, and on top of that, your brake lights wont work
oohtruck
Sep 17, 2012 08:46 AM
ACCORD0000
Oct 4, 2006 07:16 PM
