air/fuel guage install
Old Aug 23, 2005 | 05:52 AM
disposable's Avatar
Default air/fuel guage install
Does anyone know what wire i hook the guage up to on my o2? i have 2 black wires, a white wire, and a green wire...
Old Aug 23, 2005 | 07:05 AM
IHateJDM's Avatar
Default Re: air/fuel guage install (disposable)
unless that's a wideband o2, the guage won't help.
Old Aug 23, 2005 | 07:17 AM
D15Bbigred's Avatar
white wire
Old Aug 23, 2005 | 07:24 AM
DutchEG6's Avatar
witch brand of gauge do you have?
Old Aug 23, 2005 | 09:03 AM
(puma)'s Avatar
https://honda-tech.com/zerothread?id=683978
you gotta learn to search.
and i think the green wire goes to your o2 if im not mistaken.
Modified by _B_Series_ at 1:17 PM 8/23/2005
Old Aug 23, 2005 | 09:40 AM
Turbo_y8's Avatar
Default Re: air/fuel guage install (_B_Series_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _B_Series_ &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch
and i think the green wire goes to your o2 if im not mistaken.</TD></TR></TABLE>
you are mistaken all 4 wire go to the O2 sensor, one black one is the heater wire, one black on is the o2 12v green is ground white is signal
Old Aug 24, 2005 | 09:31 AM
(puma)'s Avatar
Default Re: air/fuel guage install (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">
you are mistaken all 4 wire go to the O2 sensor, one black one is the heater wire, one black on is the o2 12v green is ground white is signal</TD></TR></TABLE>
actually i was talking about just running straight to the o2 sensor, but yeh your better off running it to the ecu.
Old Aug 24, 2005 | 09:38 AM
DutchEG6's Avatar
why????
the + and - can be take off the under dash fuse box and the signal wire's go to the ecu mutch better install to me
Old Aug 24, 2005 | 09:46 AM
IHateJDM's Avatar
Default Re: air/fuel guage install (DutchEG6)
If it were me, i would put the + on any hot ignition switched wire, the - on any ground, and the signal wire on a wideband o2. It doesn't matter where the guage gets power from, just the signal. And the signal from a stock o2 is completely worthless as far as a guage is concerned.
92nahatch
Jan 28, 2008 10:04 AM
hondaj05
15
Jul 21, 2006 03:27 PM
gsr30035hatch
Mar 1, 2006 05:59 PM
wickedxboi
Mar 22, 2003 01:51 PM
