anyone dropped their oil pan down before?
Old Aug 22, 2005 | 10:21 PM
B bOy CrAyOn's Avatar
Default anyone dropped their oil pan down before?
i dropped my oil pan today cuzz a couple nuts were insde of it just running around loose that had came loose from the oil pick up line... what i was wondering is if u guys just put the gasket on the oil pan and put it up liek that or did u guys put RTV sealer like the Haynes Honda books says... and last was wich side of the gasket goes up towards the engine cuzz one side has 2 lines running down that side and the other side is completely flush... this is for my b16 by the ways
Old Aug 22, 2005 | 10:38 PM
any help?... just need to know the steps u took to puting ur oil pan back in.. any help is appreciated
Old Aug 22, 2005 | 10:41 PM
resol's Avatar
Default Re: (B bOy CrAyOn)
same step but reverse on how you took it off
Old Aug 22, 2005 | 10:42 PM
lol well yeah but i was tryna find which side of the gasket faced up and if they used RTV sealer or if its not even necessary... any help?
Old Aug 23, 2005 | 02:33 AM
MikeD718's Avatar
i used RTV when i put mine back on after tapping it for a turbo oil drain. i think i put the flat side of the gasket up since there is a groove in the pan for it.
Old Aug 23, 2005 | 02:34 AM
JDMlyfestyle's Avatar
i always add a little RTV to the Oilpan gasket. just for a little reasurrance.
Old Aug 23, 2005 | 04:59 AM
hoffman4684's Avatar
I added some RTV to mine as well when I installed my Mugen pan. Look closely at the gasket, you'll be able to tell whichside is up.
Old Aug 23, 2005 | 05:07 AM
Pioneer162's Avatar
you need to get all the crap from the old gasket cleaned off the oilpan and the bottom of the motor. The gasket will only fit one way, so it shouldn't be that hard to figure out, and yes, you'll want to put a little RTV
Old Aug 23, 2005 | 05:20 AM
mike1114's Avatar
Default Re: (Pioneer162)
No RTV unless you helms calls for it.
Most cars 92+ don't use it anymore.
put gasket flat side facing up.
Don't forget about the washwers on the flywheel side. Make sure you removed the old ones before you put the new gasket on. They are inside the gasket but sometimes stick to the block when taking the gasket off.
Old Aug 23, 2005 | 08:20 AM
nub.96ek's Avatar
Default Re: (mike1114)
Oli pan gasket + RTV = piece of mind.
Old Aug 23, 2005 | 08:22 AM
-[95cxhatch]-'s Avatar
Default Re: (nub.96ek)
Put some rtv or the grey hondabond stuff around each arch at the ends and put a small film along the entire gasket just to hold it in place. This is how my factory Honda service manual recommends
Old Aug 23, 2005 | 09:44 AM
lkailburn's Avatar
you are supposed to apply rtv to the new gasket.
Old Aug 23, 2005 | 12:02 PM
alright thnx.... anyone know how to get all the old rtv sealer stuff off the oil pan... cuzz its liek silicone... its really hard to get off
Old Aug 23, 2005 | 12:06 PM
yeah i figured out the gasket that wasnt very hard.... but this old gunky rty or whatever they used before is gettin on my nerves.. its liek silicone its hella rubberish tho.. hard to get off what did u guys use?
Old Aug 23, 2005 | 12:07 PM
to get the old **** off i mean
Old Aug 23, 2005 | 12:16 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">No RTV unless you helms calls for it.
Most cars 92+ don't use it anymore.</TD></TR></TABLE>
Are you kidding? Most cars still use something quite similiar to RTV. I use it at work all the time, it is made by permatex and it is called "The Right Stuff"
Old Aug 23, 2005 | 12:27 PM
oh well i started cleaning it off by using a really tuf wire brush... its taking the slicone stuff right off and the paint with it also...lol
Old Aug 23, 2005 | 05:29 PM
lkailburn's Avatar
you should go get a "gasket remover tool". i basically looks like a flat chisel. a careful hand and a razor blade also works. just be sure not to cut up the surface at all
Old Aug 23, 2005 | 05:43 PM
melissas_man2004's Avatar
Default Re: anyone dropped their oil pan down before? (B bOy CrAyOn)
i dropped the pan on my honda cause the gasket was leaking and fucked up my clutch so i just removed the gasket and ceaned everything and made my own gasket out of MOPAR RTV sealer. mopar seales everything.
John
Old Aug 23, 2005 | 06:01 PM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default Re: anyone dropped their oil pan down before? (melissas_man2004)
Rubber gasket right. Believe you use a little sealant in the corners. Using too much will make the gasket squeeze out. Make sure you dont torque the bolts down to hard. snug the bolts up rotating then torque them down. Have done this couple of A20 same concept. Nother tip use some 3m spray adhesive lightly on oilpan side of the gasket and it will help keep gasket in place.
Old Aug 23, 2005 | 06:05 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">Oli pan gasket + RTV = piece of mind.</TD></TR></TABLE>
Same here.
Old Aug 24, 2005 | 09:35 PM
yeah i used rtv sealer and the new gasket.,..worked out perfect so its all done.. thanx for all the tips and info
phelpsj2
Mar 9, 2010 12:16 PM
mf RENO
Aug 31, 2004 11:06 AM
T25So
Jun 25, 2004 09:08 AM
91sihatchback
Feb 3, 2004 04:30 PM
htownteg
Jan 30, 2004 07:15 PM
