Turbo d16 or b16-T
Old Aug 19, 2005 | 09:37 AM
JDMRice's Avatar
Default Turbo d16 or b16-T
I have a 2000 ex, Im trying to decide what to do with my car,
1-Turbo my stock motor or
2- Drop in a b16 and turbo that
My goals are to run low 14 high 13, and my car is a daily driver, so i need something reliable.
My question is is it worth spending 2500 (cdn) on swapping a b16 in, to gain a bit more power. Or should i just tirbo what i have and be done with it.
Old Aug 19, 2005 | 09:40 AM
dr_latino999's Avatar
Default Re: Turbo d16 or b16-T (SohcPower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower &raquo;</TD></TR><TR><TD CLASS="quote">just tirbo what i have and be done with it.</TD></TR></TABLE>
Old Aug 19, 2005 | 09:43 AM
JDMRice's Avatar
Default Re: Turbo d16 or b16-T (dr_latino999)
The thing is i dont wanna spend the time + money and then be dissapointed with the d series....maybe som e of the sohc t guys can reply...
Old Aug 19, 2005 | 09:50 AM
nerdsports's Avatar
13-14 second time slips are easily attainable with a decent turbo setup on a dseries.
search and you'll see dyno #s and what not...
Old Aug 19, 2005 | 10:09 AM
domanicivic's Avatar
8 psi with some good tuning, run a t3 with custom manifold. (still be able to keep a/c)
that will be good enough to get you to high 13's with some good tires, driving skills, and a nice clutch.
expect to spend about 3 - 4 g's cnd.
that extra 2500 from the b16 can get you rods, pistons, sleeves...
Old Aug 19, 2005 | 10:26 AM
Civicman86's Avatar
with your goals definatly go with a turbo D series. You wont be let down if you do that kit right.
Old Aug 19, 2005 | 10:32 AM
JDMRice's Avatar
Default Re: (Civicman86)
3-4 Is what im going to spend on the kit and tunning , Im going to piece my own.
Old Aug 19, 2005 | 11:18 AM
playboyace35's Avatar
Default Re: (SohcPower)
posted twice on accident.
Old Aug 19, 2005 | 11:25 AM
3-4?? MAN u can even built ur bottom end with that much money. You can hit high low 13's for sure if did it right, hell u mite even hit high 12's. I seen it happen before.
700-800 for sleeving..
500-700 for internal
so at most, for builting the bottom end, its goin to cost 1500, that still gives u 2,500 to get a turbo kit.
i pieced my own turbo kit (brand new turbo t3/t4 .50 trim) plus hondata for 2,400.
Old Aug 19, 2005 | 11:28 AM
MeanstreakCivic's Avatar
Go for the D series
The numbers you want are very easily reachable.
If you ever blow your motor you can pick one up for almost free, instead of spending major cash on a b series!
Old Aug 19, 2005 | 11:37 AM
vha27's Avatar
Default Re: (MeanstreakCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanstreakCivic &raquo;</TD></TR><TR><TD CLASS="quote">Go for the D series
If you ever blow your motor you can pick one up for almost free, instead of spending major cash on a b series!</TD></TR></TABLE>
This is the main reason I stick with a D-series motor.
Old Aug 19, 2005 | 11:55 AM
whiteef8's Avatar
yea, go d series, so whe you pull up next to me, i can spank you cuz i went "b-serious", lol j/k **** ive seen some crucial *** turbo d's man, with that much money you could easily reach/pass your goals...
Old Aug 19, 2005 | 12:01 PM
SOHC_MShue's Avatar
Turbo the D, but if you must go B pick up a ls for cheap.
Old Aug 19, 2005 | 12:02 PM
Default Re: (whiteef8)
now that im thinking again, if u dont plan to hit 12's or do too much work. Swap a ls motor in there for about $1,000. Then piece a turbo kit for about 1,900. Go either hondata or neptune. that would be anywhere from $400-600 tuned.
Tune it at 7psi and u should hit 13's easily and you not even have to worry about blowing your motor.
this way, you know ur motor is pretty safe, and when that one day comes where u feel the need of speed, just turn up the boost to like 11 and u should hit 12's with a good driver. (need to retune tho)
Old Aug 19, 2005 | 07:46 PM
JDMRice's Avatar
Default Re: Turbo d16 or b16-T (SOHC_MShue)
the reason i wrote b16 is cause of the vtec and the short gears, but now i think i have my mind made up. D series it is.
Thanks guys.
Old Aug 19, 2005 | 08:40 PM
beerbongskickass's Avatar
D-series
Old Aug 19, 2005 | 08:50 PM
MRturbo's Avatar
Default Re: Turbo d16 or b16-T (beerbongskickass)
definatly go with d-series, with that extra $2500+ u spend on the b16 u can put forged pistons and rods. and with pistons and rods, u can hit high 12's and still retain daily driver.
Old Aug 19, 2005 | 10:21 PM
reaction360's Avatar
Default Re: Turbo d16 or b16-T (tl_vang86)
Bseries! just incase some day, you wanna easily make 500+
Old Aug 20, 2005 | 05:34 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Turbo the D, but if you must go B pick up a ls for cheap.</TD></TR></TABLE>
EF9ZC
Oct 8, 2007 08:14 PM
flangemastermike
May 31, 2006 11:51 AM
saver
Oct 2, 2005 09:16 PM
beaneg6
Aug 15, 2005 05:50 PM
importdude2000
May 7, 2005 01:15 PM
