who can chip my ecu for a basemap?
Old Aug 18, 2005 | 01:02 PM
xfrankx's Avatar
Default who can chip my ecu for a basemap?
my setup will be:
obd1 b18b stock
Garret Turbo 70 ar 48 e 60-1
Small Spearco Core Intercooler
Turbonetics Wastegate with 10lb spring
Greddy Bov
Rev Hard Manifold
Dsm 450 Injectors
walbro 225 fuel pump
is there anyone on here that can make me a basemap for this setup so i can drive it till i get more $ to really get a good tune on it? this is my first turbo setup on a honda and i just want my motor to last. i looked around but i couldnt find anyone specific that can make basemaps. id like to use crome but i suppose uberdata would be ok for now
Old Aug 18, 2005 | 01:07 PM
N20civicB18's Avatar
Default Re: who can chip my ecu for a basemap? (xfrankx)
Phiz made mine (hes from CT) but any tuner can make you a basemap easily
Old Aug 18, 2005 | 01:27 PM
xfrankx's Avatar
Default Re: who can chip my ecu for a basemap? (N20civicB18)
my friend daily drives his ls turbo at 10lbs on a uberdata basemap and its fine but ive heard its not a good idea.
Old Aug 18, 2005 | 02:03 PM
what you have been told is right, that is a horrible idea. pull his pistons and look at the ring landings
Old Aug 18, 2005 | 03:36 PM
flip1199's Avatar
driving around on nothing but a basemap isnt' a good idea, granted many people still do it... i'd suggest not installing it until u can afford to get it tuned.
Old Aug 18, 2005 | 03:46 PM
alpha's Avatar
https://honda-tech.com/zerothread?id=1242991
Old Aug 18, 2005 | 04:25 PM
mtber's Avatar
Default Re: who can chip my ecu for a basemap? (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1242991</TD></TR></TABLE>
Thanks bud
Old Aug 18, 2005 | 04:43 PM
93hatched_projekt's Avatar
I would have to agree. John socketed my ecu and put a decent/modified basemap on my ecu. I would recommend this service.
Old Aug 18, 2005 | 05:25 PM
EnzoSpeed's Avatar
Default Re: who can chip my ecu for a basemap? (93hatched_projekt)
If your motor is stock (other than the turbo setup) then you can run on a basemap for as long as you want.
I had a stock motor running 8psi on an uber basemap for almost a year. My wideband showed that the afr's were almost perfect.
Uber basemaps are the **** There is nothing wrong with running on them except you will be a bit rich under boost. That's the beaty of working off of stock honda maps.
I don't get the ringland comment. I pulled my motor apart and it was frickin' mint. It had 90k miles and was boosted for a year on a basemap and the internals looked practically new.
Old Aug 18, 2005 | 06:46 PM
Default Re: who can chip my ecu for a basemap? (EnzoSpeed)
I had broken ring lands on my 77,000 mile LS motor after 3 months of boost on basemap
Old Aug 18, 2005 | 06:51 PM
xfrankx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">If your motor is stock (other than the turbo setup) then you can run on a basemap for as long as you want.
I don't get the ringland comment. I pulled my motor apart and it was frickin' mint. It had 90k miles and was boosted for a year on a basemap and the internals looked practically new.</TD></TR></TABLE>
thats what i was thinking. like i said my friend is running one fine for about 10 months now with no problems. who did your basemap?
Old Aug 18, 2005 | 08:34 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xfrankx &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i was thinking. like i said my friend is running one fine for about 10 months now with no problems. who did your basemap?</TD></TR></TABLE>
Me. It takes about 1-2 minutes to make a basemap.
Old Aug 18, 2005 | 10:04 PM
SOHCD16y8's Avatar
yeah, Ive only had my motor running now for a few hours but for the start up and break-in I used uberdata basemap that I made, under boost im running a strong 11.5 A/F. the vacuum end is a lil rich in the mid 13's to low 14's but thats just wasting gas more then hurting the motor.
Old Aug 19, 2005 | 12:50 AM
the.hamburglar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">I had broken ring lands on my 77,000 mile LS motor after 3 months of boost on basemap</TD></TR></TABLE>
man you had a basemap made...did you also have a wideband for extra safety? probably not right?
make your basemap, borrow a buddies wb02 for a day. drive around and monitor what its doing. if your a'f ratio looks good then keep it man. thats what im doing and its been only a couple weeks but everything is fine. but remember to set your timing to stock 16btc without the chip so that you will calibrate with uberdata. i forgot to do this so i drove my car on the freeway at 18btc and i heard major knock ( like a pinging sound) and then i realized i never put my timing back to stock. it now idles perfect as well. i can send you the basemap im using if you want?
Old Aug 19, 2005 | 06:57 AM
delslo93's Avatar
Default Re: who can chip my ecu for a basemap? (hamburgler)
You def. wanna go with J-K-Tuning.com (93turbo16). His ecu's are the best! Hes the only one i let touch my car.
Old Aug 19, 2005 | 09:54 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">I would have to agree. John socketed my ecu and put a decent/modified basemap on my ecu. I would recommend this service. </TD></TR></TABLE>
Thanks
aRandy
Jun 2, 2010 10:52 AM
1995civicEJ
Mar 24, 2008 07:08 PM
flyingduck04
Dec 3, 2005 04:14 PM
95si
Feb 2, 2003 04:23 AM
skellator_thoj
Jan 22, 2003 02:48 PM
