Stud Hole Cleaning
Old Aug 17, 2005 | 06:29 AM
LSEGHATCH's Avatar
Default Stud Hole Cleaning
Doing a headgasket change on my d15 and noticed there is oil/coolant in the holes for the head studs. Any way of cleaning this out really good? I already went through with a compressor and got all the **** (old gasket and what not) out but not the liquid.
Also do you guys use the red lubricant they provide for putting the studs into the block or just for the bolts themselves?
Modified by LSEGHATCH at 7:44 AM 8/17/2005
Old Aug 17, 2005 | 08:36 AM
Ekay Jay's Avatar
Default Re: Stud Hole Cleaning (LSEGHATCH)
I put ARP molly lube on my head studs. Remember that Depending on what u put on the bolts determines what ur supose to torqe the too.
Old Aug 17, 2005 | 08:45 AM
LSEGHATCH's Avatar
Default Re: Stud Hole Cleaning (JdM DA InTeGrA)
I AM using the lube, but don't know if I need to put it on the studs when installing them in the block or just on the nuts when bolting head to block
black0hatch
Honda CR-V & Element
Aug 30, 2012 01:29 PM
The93egg
Mar 1, 2009 11:02 AM
GSR_hatch936
May 27, 2008 06:09 PM
LSEGHATCH
Aug 19, 2005 10:53 AM
LSEGHATCH
Aug 17, 2005 07:02 AM
