4.7 final drive 1/4 mile, need to shift into 5th?
Old Aug 17, 2005 | 04:39 AM
bootlegtrader's Avatar
Default 4.7 final drive 1/4 mile, need to shift into 5th?
of you guys with the 4.7 final drive do you have to shift into 5th? thanks.
Old Aug 17, 2005 | 04:43 AM
Dave_B's Avatar
Can't really specifically answer that one but I wouldn't think so because I just shift into 4th on my stock FD. as I cross the line with my mad tight blink of the flashers But seriously I doubt it.
Old Aug 17, 2005 | 05:13 AM
Black R's Avatar
25 Year Member
no.
With a 4.9 final, I'm still in 4th.....
Old Aug 17, 2005 | 05:15 AM
jeremy.'s Avatar
Default Re: (Black R)
shouldn't have to
Old Aug 17, 2005 | 05:38 AM
citrus3000psi's Avatar
depends how much power your making.
Old Aug 17, 2005 | 05:52 AM
b19coupe's Avatar
Default Re: 4.7 final drive 1/4 mile, need to shift into 5th? (bootlegtrader)
Depends on your redline and your mph when you go through the traps.
And I don't at 113 with a 9,200 fuel cut.
Old Aug 17, 2005 | 05:56 AM
jeremy.'s Avatar
Default Re: (citrus3000psi)
and how fast you get down the strip
Old Aug 17, 2005 | 06:22 AM
realis9's Avatar
96 with jdm tranny 4.7 final in 4th gear.
Old Aug 17, 2005 | 07:05 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 4.7 final drive 1/4 mile, need to shift into 5th? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Depends on your redline and your mph when you go through the traps.</TD></TR></TABLE>
Yes, exactly.
For example, a bone stock USM ITR (with 4.4 stock FD) with a stock 8400 RPM redline would hit redline in fourth gear, and need to upshift, at 117.6 mph.
If you're talking about the JDM 4.785 FD that otherwise has USM stock gears, then it would hit 8400 RPM at 117.6 * 4.4 / 4.785 = 108.2 mph. Different redline, different fourth gear ratio, different FD? Just multiply and divide to find the answer.
Old Aug 17, 2005 | 07:44 AM
Dave_B's Avatar
The all and knowledgable Ken has spoken. But yeah that makes sense.
Old Aug 17, 2005 | 07:49 AM
CWTegRNo.160's Avatar
Default Re: (Dave_B)
stock FD i was just barely shifting into 4th at the line
Old Aug 17, 2005 | 08:55 AM
AK94GSR's Avatar
Default Re: (CWTegRNo.160)
with mine i would be close to the top of 4th before the line
all depend on power and launch
skunked's Avatar
And I don't at 113 with a 9,200 fuel cut.</TD></TR></TABLE>
And slick/tire diameter makes a difference......
Old Aug 17, 2005 | 09:06 AM
Default Re: 4.7 final drive 1/4 mile, need to shift into 5th? (skunked)
cool. thanks guys. i saw on either the forced induction or all motor forum, that some people were at 7800 rpms in forth going around 115. i have the 4.4 but have not been to the track yet.
Old Aug 17, 2005 | 09:41 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">no.
With a 4.9 final, I'm still in 4th..... </TD></TR></TABLE>
you weren't launching right....
with 4.785 final 8500 rpms
i would bounce rev limiter last 100-200 feet....was faster to do that than to shift into 5th
with 4.785 final 7200 rpms rev limiter
i would be in 5th in the 1/8 mile!!!!!!!
Old Aug 17, 2005 | 09:58 AM
Dancing is Forbidden's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
i would be in 5th in the 1/8 mile!!!!!!!</TD></TR></TABLE>
Chad thats over a 90mph trap in the eighth. I dunno about that and an LS. I was in 4th in the eighth though
Old Aug 17, 2005 | 11:02 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">And slick/tire diameter makes a difference......</TD></TR></TABLE>
The tire diameter doesn't affect the relationship between the RPMs (redline) and the speed indicated on the speedometer. However, it affects the speedometer error (the difference between the indicated speed and the actual speed).
Old Aug 17, 2005 | 11:10 AM
skunked's Avatar
Default Re: 4.7 final drive 1/4 mile, need to shift into 5th? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
I was simply saying tire size will also dictate what rpm you are at going through the traps just like your gear ratios do. If you are in a situation where you are having to shift to 5th before the traps, go to a bigger tire and you won't need 5th as long as you have the power for the larger tire.
I don't know about you but I look at the ET slip for MPH not my speedometer........
Old Aug 17, 2005 | 11:17 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">I was simply saying tire size will also dictate what rpm you are at going through the traps just like your gear ratios do.</TD></TR></TABLE>
Yes, I realize that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">If you are in a situation where you are having to shift to 5th before the traps, go to a bigger tire and you won't need 5th as long as you have the power for the larger tire.</TD></TR></TABLE>
Sure, it's just like getting a taller FD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">I don't know about you but I look at the ET slip for MPH not my speedometer........</TD></TR></TABLE>
Yes, but when you're deciding when to shift, you're probably looking at your tach...
Old Aug 17, 2005 | 11:32 AM
skunked's Avatar
Right, Tach not speedometer.
Old Aug 17, 2005 | 04:49 PM
Black R's Avatar
25 Year Member
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">you weren't launching right....
.....you never had an itr, so you're not even allowed to post here.
What was your setup Chad? Was that with the bottle?
Old Aug 17, 2005 | 09:15 PM
IN VTEC's Avatar
113mph, wow. I only wish I could trap that high.
Old Aug 22, 2005 | 04:10 AM
Black R's Avatar
25 Year Member
Default Re: 4.7 final drive 1/4 mile, need to shift into 5th? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">113mph, wow. I only wish I could trap that high.</TD></TR></TABLE>
.....perhaps he's reply back with what size tyre and tranny he's using.
Rob97'SH
Transmission & Drivetrain
Jun 16, 2009 09:01 AM
Rob97'SH
Jun 15, 2009 08:31 PM
CivicUtah
11
Oct 2, 2007 04:04 PM
TypeR0149
Oct 20, 2003 10:22 PM
underrated99si
Jun 23, 2002 08:13 AM
