which belt?
Old Aug 16, 2005 | 03:16 PM
pyrohardcore's Avatar
Default which belt?
i need to figure out which belt to use on my h22. its in an EG and its the altenator belt minus the AC compressor. I'm sure someone else has done this swap. perhaps someone could tell me what belt to use. thanks.
Old Aug 16, 2005 | 06:19 PM
Lord Helmet's Avatar
Default Re: which belt? (pyrohardcore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrohardcore &raquo;</TD></TR><TR><TD CLASS="quote">i need to figure out which belt to use on my h22. its in an EG and its the altenator belt minus the AC compressor. I'm sure someone else has done this swap. perhaps someone could tell me what belt to use. thanks.</TD></TR></TABLE>
Your question is VERY VAGUE be more specific in you question. What about the belt? Is it wrong? damaged?, etc....
Old Aug 16, 2005 | 08:43 PM
Default Re: which belt? (Lord Helmet)
uhhh. i dont have the belt. so i need to know the proper size to use/purchase for an H22's altenator belt minus the AC compressor. because i dont have an AC compressor.
Old Aug 17, 2005 | 08:31 AM
dognutz's Avatar
This is easy. Just take a non streching piece of rope/string and wrap it around the pulley's that will be used. This only needs to be accurate to about 1/2 inch. Make sure all the adjusters in are in the middle of their adjustment range. Measure the string, and tell the auto parts place how many inches you have and they should (if their any good) be able to give you the right sized belt. The last four numbers of the belt part number should be the same as the inches measured. i.e. 31.5 inches measured = 3150 (I think if I remeber correctly). Note this is just an example not the size you need. I used this method on my gsr to eg hatch swap with no problem.
Old Aug 17, 2005 | 10:26 AM
anothersickhatch's Avatar
Default Re: which belt? (dognutz)
why dont you just go to the honda dealer and get an h22 alternator belt? whats wrong with doing that? the motor's parts have nothing to do with the car in this situation.
Old Aug 17, 2005 | 07:55 PM
Default Re: which belt? (anothersickhatch)
isn't the AC compressor on the same belt as the altenator?
and i'm aware of the string thing, i just figured maybe someone would know from havin done this swap.
Old Aug 17, 2005 | 10:20 PM
the ac compressor and the alternator have two different belts and two separate slots on the pulley.
Old Aug 19, 2005 | 10:50 PM
ok, checkin with places trying to find the alt belt, yeilded me being told repeatedly that its an "a/c & altenator belt" plus when i look into the car, yea, one belt needed.
its a 97 SH block if that helps anyone.
Old Aug 21, 2005 | 06:55 AM
bump
Old Aug 21, 2005 | 05:47 PM
38.5" 5 rib. just so everyone knows.
FeelTheBass
May 15, 2014 08:59 AM
19crx93
22
Aug 16, 2010 03:46 PM
fastlane2
Feb 20, 2010 07:57 PM
shyboi4u
Aug 4, 2005 03:54 PM
NoLipRacen
Mar 13, 2004 01:01 AM
