d16z6 running rich in vtec
Old Aug 15, 2005 | 10:35 AM
reconstructdead's Avatar
Default d16z6 running rich in vtec
right when i hit vtec i get a lot of black smoke, im going to replace the O2 sensor and see if that helps...im looking to do a swap soon. (my motor has 278,000 mi) any other suggestions? any info would help. thanks.
Old Aug 15, 2005 | 10:37 AM
Deemeetree's Avatar
Electrician
Once VTEC engages, it's normal to have a little smoke come out of the exhaust. When the crossover takes place, the ECU does dump more fuel to make up for the excess amount of air coming into the cylinder.
Old Aug 15, 2005 | 01:41 PM
Default Re: (Deemeetree)
its coming out pretty thick.....and when idling it spits little drops of black on the pavement sometimes.
Old Aug 15, 2005 | 08:42 PM
all_conference's Avatar
Default Re: d16z6 running rich in vtec (reconstructdead)
I think you should save that money going towards the O2 sensor for the swap. 278k is a lot on that motor. Not worth fixing anymore. What made you jump to the O2 sensor as a problem? Is it because you get CEL?
Old Aug 17, 2005 | 12:26 PM
Default Re: d16z6 running rich in vtec (all_conference)
no im not getting CEL. I just thought the O2 sensor would help with running too rich.
Old Aug 17, 2005 | 12:48 PM
JDM-Civic-Hatch's Avatar
the black smoke is no biggie. thats fuel.
but the drops coming out of your exhaust is probably condensation. just water vapor. do you have stock exhaust?muffler? my old coupe smoke black in vtec w/128,000. its nothing. also, do you have a adjustable fuel pressure regulator?
-Chris
Old Aug 21, 2005 | 12:03 PM
Default Re: (JDM-Civic-Hatch)
i have a custom cat-back with a can-style muffler.....and i do not have an adjustable fuel pressure regulator.
Old Aug 21, 2005 | 12:10 PM
Deemeetree's Avatar
Electrician
Is raw fuel coming out of your exhaust or water?
Old Aug 22, 2005 | 09:43 AM
the only thing that comes out of my exhaust is black drops of moisture sometimes when its idling, and it smokes a lot when i get on it hard.
Old Aug 22, 2005 | 09:47 AM
SandstormGT's Avatar
its just running to rich, I know your not getting a CEL, but not everything throws a CEL if it's bad, I just got my TPS light to go off after 2 TPS's, I just replaced the whole throttle body, i was dumping hella black smoke when I was in limp mode from it running so rich, but everything is fine now.
elmejor
11
Aug 24, 2008 08:14 PM
Midori Green
28
Oct 18, 2007 09:43 PM
sexyrex
Oct 22, 2006 04:33 PM
B16b-EJ8
10
Sep 22, 2006 10:52 PM
j0nptw
28
May 1, 2005 12:05 AM
