perfect built block for boost
Old Aug 15, 2005 | 10:19 AM
tobe1424's Avatar
Default perfect built block for boost
does anyone here has like a guide or something on how to perfectly build a b18 ls block for boost and reliability...
Old Aug 15, 2005 | 11:48 AM
stealthmode62's Avatar
Default Re: perfect built block for boost (tobe1424)
Perception plays a key roll in the term "perfectly built".
Old Aug 15, 2005 | 12:02 PM
tobe1424's Avatar
Default Re: perfect built block for boost (stealthmode62)
well i i know there is nothing perfect but what i mean is something that would last for a long time without blowing more or less but real potention
Old Aug 15, 2005 | 01:08 PM
BoOstedEM1's Avatar
Also depends on who does the build..cause most of the build is all about clearances...and measurements....feel me.
Old Aug 15, 2005 | 03:10 PM
Default Re: perfect built block for boost (BoOstedEM1)
There are so many different variables involved, with many combinations that would last. I agree that clearances and measurements also play a big role in the "lasting" and ultimately the "perfect" block.
Old Aug 15, 2005 | 05:11 PM
tobe1424's Avatar
so is there any like page or w.e on how to build this block more or less to perfection
Old Aug 15, 2005 | 07:30 PM
BenzTek134's Avatar
if your planning on running high boost levels like 20+ look into the AEBS cylinder sleeves they have been dyno tested at 70+ psi and did not crack or warp the deck surface. also when talking to them the recommend highly the ross pistions which are made for forced induction cars. when i had them build the bottom end of my turbo type r they did a very good job also they recommend total seal piston rings and depending on the application maybe custom crank bearings. give them a call they are very helpful and can point you in the right direction. good luck man.
Old Aug 15, 2005 | 07:35 PM
BenzTek134's Avatar
Default Re: perfect built block for boost (BenzTek134)
correction dyno tested at 55psi boost
there phone number is (858) 693-3200
http://www.aebsracing.com
Old Aug 16, 2005 | 10:11 AM
tobe1424's Avatar
thanx i appreciate it...
Boostin_GSR
Apr 4, 2007 12:21 AM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
94TealGSR
Feb 8, 2003 08:39 AM
The_Robster
Oct 30, 2002 02:41 PM
B18CHatch
Oct 18, 2001 03:06 PM
