how much will bottom end hold...
SO why did you leave it to stock compression..if your turboing..itlll hold probably 15 pounds..of rip..but with the right tunning and set up..higher than that..depending on who did build and how it was done...
reason why i left stock compression cuz if i put low compression piston i will be able to boost alot more but on honda it will cause alot of turbo lag and it will take a while to hit that boost on the other hand stock compression you will get more or less the same hp with less turbo lag and more low end power..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote">It will hold 250 kilograms If you pack it tight</TD></TR></TABLE>
hahaha, that was pretty funny
gorillaglue#4
Apr 27, 2017 06:48 PM
tobe1424
12
Jan 17, 2006 12:17 PM
accordfreak
Jul 30, 2002 11:57 PM
