CODE 21 and CODE 22
Old Aug 15, 2005 | 09:46 AM
jdm stan's Avatar
Default CODE 21 and CODE 22
Well guys when i stay under 5.2 grand i get code 21 that is the V Tec Spool Solenoid valve but when i go over 5.2 grand i get code 22 V tec pressure valve do u think i should just get a new solenoid and **** cause i am sick of doin of this crap 2 try and just get v tec on a single cam but i want v tec. I Need HElP badly so can some one HELP PLEASE PLEASE holla at ur boy boy
Old Aug 15, 2005 | 09:49 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: CODE 21 and CODE 22 (jdm stan)
holla at your boy?
Retard.
Check your oil level, if you dont have enough oil you will get those codes. Otherwise check the wiring going to the solenoid and to the pressure sensor, make sure they are ok. Last thing would be to replace the sensor.
Old Aug 15, 2005 | 10:28 AM
jdm stan's Avatar
Default Re: CODE 21 and CODE 22 (JDM_Ej)
yea the oil level is good and all the wires r hook up right. Should i just buy a new switch r just change the whole solenoid lol yea holla at boy boy means give me a response aww i can't explain it.
aztigen_eh2
Feb 7, 2008 08:15 PM
Fuster_Cluck
May 15, 2003 10:05 AM
89Civic
Jun 11, 2002 08:36 PM
lsvtec42
Mar 8, 2002 04:01 PM
boost killz
Jul 15, 2001 12:24 PM
