**FOR SALE D-Series Individual Throttle Bodies FOR SALE**
ITB's built for any D-Series engine. Utilizing GSX-R 1000 Throttle Bodies. Everything included is as follows:
-Complete ITB system
-Stock GSX-R 1000 injector fittings blocked off for vaccum fittings
-Fitting for Brake Booster
-Fitting for Fuel Pressure Regulator
-Fitting for MAP (Manifold Absolute Pressure)
-Fitting for PCV (Post Crankcase Ventilation)
-Coolant fitting modified to clear Throttle
-Throttle Bracket extention welded to fit stock cable
-Pre-Set TPS at a PERFECT .50volts
-CROME tune chip for D16Z6, it should work on other applications (Do your homework first). The tune has got WOT perfectly nailed... The car absolutely screams with this chip in.
Installed on my D16Z6...
All the Vaccum Fittings... PCV, MAP, FPR, Brake Booster.
Throttle Bracket extention welded...
Coolant Fitting modified to clear Throttle...
Throttle Closed...
Throttle Open...
Here are a few videos with the ITB's on...
-First start up...
-Showing off the Throughty
The kit is bolt in... Absolutely no fabrication work needed.
The asking price is $350.00 Shipped OBO. Feel free to PM me with any questions, offers, extra picture requests, etc.
Thanks for looking,
Modified by ZedEx at 12:05 PM 8/14/2005
Modified by ZedEx at 10:04 PM 8/15/2005
Throttle Closed...
Throttle Open...
-First start up...
Thanks for looking,
