everyone with "intake"
Old Aug 12, 2005 | 11:23 AM
coupon's Avatar
Default everyone with "intake"
ill get a pic up soon but...
i cant just simply put a filter directly on the compressor b/c of space issues, i was wondering about getting a plastic or rubber piece from home depot clamp it on the compressor and get a k/n or apexi filter. anyone have a set up like this? or is there anything wrong with having a plastic or rubber piece?
Old Aug 12, 2005 | 11:39 AM
SHystrdyGSRtdy's Avatar
Default Re: everyone with "intake" (coupon)
it might melt?
you can have a turbo coupler on the inlet and attach a pipe to it and a filter to that pipe.
Old Aug 12, 2005 | 11:50 AM
coupon's Avatar
Default Re: everyone with "intake" (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">it might melt?
you can have a turbo coupler on the inlet and attach a pipe to it and a filter to that pipe. </TD></TR></TABLE>
pics of this? and who sells them?
Old Aug 12, 2005 | 11:54 AM
here's a pic of my coupler:
then just get a piece of piping (same diameter as your inlet). attach them together with some t-bolts
i'm sure you can find everything here:
http://www.atpturbo.com/Merchant2/merchant.mvc
if you search around, you may be able to find better prices, but atp turbo is readily available.
Old Aug 12, 2005 | 12:04 PM
ATS*Mark's Avatar
OG triple OG
i had my fabricator make one for me , took him about 5 minutes
Old Aug 12, 2005 | 12:19 PM
mike1114's Avatar
Default Re: everyone with "intake" (Hella_JDM)
Home depo style couplings will melt eventually (quckly) and possibly suck up a piece into your turbo.
My Home depot motorsports coupling didn't last long at all.
Get the right kind of coupling 3 ply silicone kind from local race shop or online.
Old Aug 12, 2005 | 12:46 PM
inspyral's Avatar
Can't really see too well in this pic, but I use a 45 degree silicone coupler and an A'PEXi filter.
Old Aug 12, 2005 | 01:24 PM
coupon's Avatar
Default Re: (inspyral)
where are the best place to buy 3" couplers? k&n filters?
Old Aug 12, 2005 | 06:28 PM
Finland's Avatar
I made a true cold air setup, turbo inlet tube is T304 stainless to avoid heat soak, the U bend (not shown) is aluminum, there's a huge K&N filter at the end which resides in my right inner fender. I also have a venturi tube in the turbo inlet tube that helps evacuate my crank case.
Old Aug 12, 2005 | 09:42 PM
coupon's Avatar
Default Re: (Boondock Saint)
Old Aug 13, 2005 | 05:55 AM
scartail's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">I made a true cold air setup, turbo inlet tube is T304 stainless to avoid heat soak, the U bend (not shown) is aluminum, there's a huge K&N filter at the end which resides in my right inner fender. I also have a venturi tube in the turbo inlet tube that helps evacuate my crank case.
Did you have any trouble with your clutch hardline? I can't get my aluminum elbow on, b/c of this hardline.
Old Aug 13, 2005 | 10:01 AM
KeyserSoze's Avatar
Default Re: (coupon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coupon &raquo;</TD></TR><TR><TD CLASS="quote">
where are the best place to buy 3" couplers? k&n filters?</TD></TR></TABLE>
I get my couplers off of ebay, someone earlier in the post had one. They are made by HTS (high temp silicone). The guy there is really cool, I have gone to his dist shop in apple valley and he was super nice. His products are high quality as well.
Old Aug 13, 2005 | 11:10 AM
Finland's Avatar
Default Re: (scartail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail &raquo;</TD></TR><TR><TD CLASS="quote">Did you have any trouble with your clutch hardline? I can't get my aluminum elbow on, b/c of this hardline.</TD></TR></TABLE>
No, no problems there, perhaps your manifold puts the turbo at a different angle?
Can you bend the line out of the way?
Old Aug 13, 2005 | 12:16 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
i had my fabricator make one for me , took him about 5 minutes </TD></TR></TABLE>
you shoudl paint them pipes soon ..
i slap a filter directly on my turbo but my manifolds FR stylin.
2x0
May 9, 2018 09:19 AM
pjd
Mar 18, 2013 10:55 PM
honda_andy
May 29, 2006 02:40 PM
B18B1DOHC
Dec 20, 2003 02:09 AM
hondalawnmower
Oct 30, 2001 11:28 AM
