What to substance to use when threading arp head studs into block
Old Aug 11, 2005 | 04:34 PM
Nisif's Avatar
Default What to substance to use when threading arp head studs into block
I'm not talking about threads at the top of the studs (I'll be using the arp moly base lube for that) where the nuts fasten to. But wondering how tight and if I should use oil or some other type of grease for the threads that go into the block, Not sure if it matters too much but wanted to know what you did, thanks
Old Aug 11, 2005 | 06:31 PM
Pandahatch's Avatar
I always put a little motor oil on the threads and then torque the studs to 10lbs, I know they say don't torque them, but I've always found that method to work best.
Old Aug 11, 2005 | 06:48 PM
onepoint6i's Avatar
Default Re: (PandaHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch &raquo;</TD></TR><TR><TD CLASS="quote">I always put a little motor oil on the threads and then torque the studs to 10lbs, I know they say don't torque them, but I've always found that method to work best. </TD></TR></TABLE>
yeah they say dont torque them, but i guess 10lbs isnt much...I just screw them all the way down snug em alittle with the 3/8 ratchet, i also just use the moly grease cause its there already..
Old Aug 11, 2005 | 09:13 PM
Nisif's Avatar
Default Re: (1.6i)
Okay thanks guys, I'll just use the moly based grease it comes with and hand tighten it with the allen key
boost and bass
Aug 15, 2008 06:55 PM
7808
Mar 23, 2007 04:36 PM
flip1199
Aug 2, 2005 12:28 PM
NWHybrid
Mar 29, 2004 09:46 PM
D16A6Turbo
Dec 2, 2002 11:24 AM
