Idle problems
Old Aug 9, 2005 | 07:23 PM
UNKNOWN_MEMBER's Avatar
Default Idle problems
When i give the car gas when it's in neutral, the idle will go up then go down slowly, then go down natraully, then back again then down normal. Here's the thing, everything idles good with the IACV not connected. I already cleaned the IACV also.
Old Aug 9, 2005 | 10:06 PM
ttt
Old Aug 10, 2005 | 02:57 AM
Default Re: (UNKNOWN_MEMBER)
come on.......
Old Aug 10, 2005 | 09:59 PM
ttt
Old Aug 10, 2005 | 10:26 PM
Sinner's Avatar
your when your IACV is disconnected the car idles correctly? Have you check the vaccum on the car? maybe you have a cracked air hose. also a funky idle can come from air in your cooling system, but since you havnt messed with that you should be ok. when my distributor was going bad cause my idle to move around. just a few ideas
Nick
Old Aug 10, 2005 | 10:45 PM
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">your when your IACV is disconnected the car idles correctly? Have you check the vaccum on the car? maybe you have a cracked air hose. also a funky idle can come from air in your cooling system, but since you havnt messed with that you should be ok. when my distributor was going bad cause my idle to move around. just a few ideas
Nick</TD></TR></TABLE>well i just got the motor in the car. it was running good before i dropped it in though. I bled the cooling system already though. What do you mean by check vacuum? One thign i noticed while i was driving today is at idle my tach would jump from under 1 to alittle above 1 but the engine wouldn't rev up and my VAFC would read 800 something rpm. I read that ignitor could be the cause for that. But why would it idle perfect with the iacv disconnected?
Old Aug 11, 2005 | 08:56 PM
nope no holes in lines. Also idle is high now, 1k and the idle screw is turned in all the way
KidDxbOrI
Jan 14, 2014 04:29 PM
b20bFourDoorCivicLX
Apr 16, 2013 08:34 PM
b16acrxer
Aug 31, 2004 09:02 AM
doh boy
Aug 19, 2003 09:34 AM
94dxt
Aug 14, 2003 09:03 PM
