SOHC: ARP 2000 rod bolt torque specs in D16A6
Old Aug 9, 2005 | 02:43 PM
W O T's Avatar
Default SOHC: ARP 2000 rod bolt torque specs in D16A6
Hey guys
I need the torque specs to torque down my ARP 2000 rod bolts for my eagle rods
They are in a D16A6
Hope someone has them off hand
Old Aug 9, 2005 | 05:12 PM
W O T's Avatar
Default Re: SOHC: ARP 2000 rod bolt torque specs in D16A6 (W O T)
Old Aug 9, 2005 | 09:16 PM
W O T's Avatar
Old Aug 12, 2005 | 12:00 PM
W O T's Avatar
Old Aug 12, 2005 | 01:22 PM
Steve91's Avatar
Just call ARP, but its probably 40ftlbs
Old Aug 12, 2005 | 02:47 PM
s2kdre's Avatar
Default Re: SOHC: ARP 2000 rod bolt torque specs in D16A6 (Steve91)
on my ls its 28 foot pounds.
Old Aug 12, 2005 | 09:55 PM
W O T's Avatar
Default Re: SOHC: ARP 2000 rod bolt torque specs in D16A6 (jdmhonda)
Old Feb 7, 2006 | 03:59 PM
joshb_'s Avatar
43 ft lbs
Old Feb 7, 2006 | 05:06 PM
non-VTEC's Avatar
if its a 3/8" bolt head it should be 28ft/lbs
if its a 7/17" bolt head it should be 43ft/lbs
Old Feb 8, 2006 | 03:37 PM
joshb_'s Avatar
Default Re: SOHC: ARP 2000 rod bolt torque specs in D16A6 (non-VTEC)
I have the arp 2000 bolts that a 11mm socket went on 2 and i called eagle twice and they said 43.....My machine shop resized the journal size at 48 and thats what im no running
Old Apr 22, 2007 | 02:25 PM
Boricuanology's Avatar
Default Re: SOHC: ARP 2000 rod bolt torque specs in D16A6 (joshb_)
Let me help you out so you don't ended up doing the same stupid mistake I did.
I belived all eagle rods are the same for the 1.6 SOHC.
Acording to what it says on my spec sheet.
Check to see if you rods came with the upgraded bolt that it is 7/16, 12 point head bolt. If yours did then the torque is 43lbs. NOT 75LBS like I did.
You see the spec sheet is so confusing because it ask you you what size of bolt yours have, mines were the 7/16. and in the bolt itself says ARP 2000 and then it says 75lbs. This bolt was and upgrade to the 3/8 bolt thats torque to 43lbs.
Modified by Boricuanology at 6:56 PM 5/1/2007
Old Apr 22, 2007 | 04:01 PM
W O T's Avatar
Default Re: SOHC: ARP 2000 rod bolt torque specs in D16A6 (Boricuanology)
18 months ago buddy, motor is already blown lol
Old Apr 24, 2007 | 04:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">18 months ago buddy, motor is already blown lol</TD></TR></TABLE>
LOL, didn't realized how old is the post, anyway there are still a lot of people out there confused with what the paper spec paper says and they are still making the same mistake, like myself. so by reopening threads like this it should help out so people out there.
Sorry about your engine thou!!
JDMCRX
Feb 1, 2015 08:43 AM
CaliforniaDad
Jul 11, 2011 12:17 PM
viera
Feb 4, 2010 09:27 AM
2phast
Jun 25, 2005 08:41 PM
Scott - 93HB Si
Jul 30, 2003 05:19 AM
