Turbo Project Nearing completion, opinions, advice, pointers, all welcome
Old Aug 7, 2005 | 09:12 PM
ProjectDarkBlack's Avatar
Default Turbo Project Nearing completion, opinions, advice, pointers, all welcome
Well its been over a year of me saving up now, making $8 an hour. I have come up on about $2400 of my final budget (accident, and my dad let me sell his dirtrbike) and my turbo project is about ready to be installed and tuned. Everything major has been ordered except a sandwich feed adapter. The only thing I have done to my since I started saving is 98+ tails, leather rear seats, and I changed the wheels to Rota C8 16x7`s.
My list of parts is pretty long now but it is a stock block B18B1
<U>Cylinder Head</U>: ARP studs, fel-pro top end gasket set, 4 bolt adj cam gears
<U>Fuel System</U> : RC550 sat injectors, Aeromotive fpr, Walbro 255
<U>Management/gauges</U> : Hondata S200b P75, Greddy Profec B-spec II, PLX m-300 wideband, autometer sport-comp oil pressure/temp
<U>Engine acessories</U>: GE vacuum manifold, endyn catch tank, PWR civic dual core half size radiator, AEM underdrive pulleys (last two are installed already)
<U>Exhaust</U> Peakboost Manifold and 3" downpipe, K-teller 3" ss piping, magnaflow 3" ss muffler
<U>Turbo Kit:</U> made in april of 03, peakboost turbo kit consisting of SS equal length manifold, Garrett T3/T40E .60 trim, 2.5 mild steel plumbing, 3" downpipe with flexpipe, TiAL 38mm wastegate and 50mm BOV, earls weldless fittings -4 A.N. feed -10 A.N. return, T bolt clamps, 12:1 fmu (its for sale )
<U>Misc</U>: ATP oil restrictor, exedy stage 1 clutch//pp, exedy lightweight flywheel (both installed and broken in), ATP downpipe studs. Still missing nuts&bolts as I got the kit used (in the box) and it was missing these. Would still like to get a greddy oil feed adapter. Also have ES motor mount inserts
<U>Random info</U>:
I was debating on where I should get it tuned, Modacar (30 min drive) or DSR (1:30) drive. I will probably get an OEM tune up kit for the ignition before it hits the dyno, I also need to buy the NGK`s and an air filter set-up. My fan doesn`t come on and I never rembered it coming (doesn` go above half temp) so I will probably hard wire it in. I have heat wrap but I have heard that it is really bad for the downpipe. I would like to create ducting with sheet metal to scavenge all of the airflow possible for the radiator, intercooler, and intake.
Anyways this is going to be my project thread and I will keep it updated. I am planning or hoping for 250whp on 8-9 psi, with 6psi for normal around town fun.
Also hoping for high high 12`s once everything is dialed in. Let me know what you guys think!
<U>props</U>: Phoenix Turbo , Flamenco-T , AF-Performance (wiredricky), Team-integra , ATP , JEG`s , XtremeAznX (i think thats his sn) , Quad-Damage , Kaeding Performance , Robear Racing , I`m sure I missed a few but above all, all you Honda-tech bitchus!!1
Modified by ProjectDarkBlack at 6:26 PM 8/11/2005
Old Aug 7, 2005 | 09:36 PM
SHystrdyGSRtdy's Avatar
Default Re: Turbo Project Nearing completion, opinions, advice, pointers, all welcome (ProjectDarkBlack)
good job, i'd get an oil restrictor for the turbo if i were you and a greddy carb legal sticker.. shhhh
Old Aug 7, 2005 | 10:08 PM
Default Re: Turbo Project Nearing completion, opinions, advice, pointers, all welcome (SHystrdyGSRtdy)
oil restrictor is in the list The sticker however.... o well its illegal to modify your fuel pressure anyways.
Old Aug 7, 2005 | 10:21 PM
ah, i see it now... you got your slim fan?
Old Aug 8, 2005 | 05:47 AM
cuin9sec
Guest
Posts: n/a
nice setup...later on down the road you should throw a vtec head on.
Old Aug 8, 2005 | 08:24 AM
Default Re: (t67civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t67civic &raquo;</TD></TR><TR><TD CLASS="quote">nice setup...later on down the road you should throw a vtec head on. </TD></TR></TABLE> I am seriously considering this but not for a year at least, might just build an Ls head for 8k rpm
Old Aug 8, 2005 | 08:34 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (ProjectDarkBlack)
coming along nicely
give casey a call at MODACAR, they have tuned a couple of the PeakBoost kits, and he owns one himself .
feel free to pm me with any questions
Old Aug 8, 2005 | 08:50 AM
Default Re: (PhoenixTurbo.com)
Call him? I am going there today at 12 to get my basemap
Old Aug 8, 2005 | 09:18 AM
Sohc Driver's Avatar
Looks like you got everything you need. I think your setup is ready to go. You maybe missing a turbo timer though
Khoi
Old Aug 8, 2005 | 03:09 PM
Default Re: (Sohc Driver)
I am going to get another alarm soon, I will get one afterwards. Got my basemap today and asked casey if they are hiring any shop bitches, apparently he is not involved in hiring "the shop bitchus"
Old Aug 11, 2005 | 12:50 PM
Okay right now some of the issues I am having: Cant seem to get the rights size bolts for the turbine flange, I have 10mm stainless ones but I think I need 11mm, also I have no rubber o ring gasket for the tial BOV. The intercooler piping is for a civic, and needs to be modified for my integra, and I want to rework the dumptube. The exhaust also has to be fitted and welded. I put 2 of the motor mount inserts in yesterday but couldn`t get the back one in
Old Aug 11, 2005 | 01:14 PM
Quad-Damag's Avatar
enjoy my hondata s200
Old Aug 14, 2005 | 06:49 PM
Default Re: (Quad-Damage)
anyone know where I can get a gasket for the v-band clamp on the TiAL bov, and what size bolts to use for the turbine/mani flange?
Old Aug 14, 2005 | 06:55 PM
nojoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where I can get a gasket for the v-band clamp on the TiAL bov, and what size bolts to use for the turbine/mani flange?</TD></TR></TABLE>
V-Band clamps don't require a gasket, they are self-sealing.
Old Aug 14, 2005 | 07:45 PM
Default Re: (nojoke)
ok cool, I was just worried because I saw the gasket in a few pictures of the BOV
PoorBoy_96civic
Aug 2, 2010 08:45 AM
H2on0da3
Northeast (Sales)
Jan 6, 2008 07:02 PM
H2on0da3
Nov 10, 2007 07:47 AM
B00ST2nR
Aug 17, 2004 04:11 PM
B18 CYA
May 22, 2004 11:22 AM
