DIY oil restrictor. Cost = $3
Old Aug 7, 2005 | 04:48 PM
CRXDrew's Avatar
Default DIY oil restrictor. Cost = $3
So I had a 14b that smoked quite bit and a while ago I bought an oil restrictor from an aircraft supply store. The hole was a bit small. And the concensus seems to be that .060 is a good size for the hole. I believe ATP turbo or some other company sells them with this size hole. Anyway.. I paid 10 shipped. And It worked great.
then I got thinking...
Parts list:
-1 1/8NPT double male
-1 1/8NPT Double female
-1 1/8NPT square head plug
-small length of teflon tape
Of course I did have tools sitting around which I used... and maybe you don't have them. In that case... you should have them and shame on you.
Dremel w/ cutting wheel
1/8 NPT tap
1/16 drill bit
drill
beer
small screwdriver
-so buy the parts... get the plug... and cut the very tip of the threads off. You will be using just the tip. NPT is tapered a bit so you won't be able to fit much of the plug down into the female but the very tip should go all the way in.
-Get the double female and tap one side. This will allow the lil plug to go even deeper into the hole.
-Get the lil disc of plug and cut a groove into it so you can use a screwdriver to twist the plug into the thread.
-screw the disc of plug into the tapped end of the double female.
-Now get the 1/16 bit and drill a hole right in the middle of the plug.
-Now that all the fine motor skill stuff is done go have a beer.
-put a lil teflon tape on the end of the double male and screw it into the tapped side of the double female.
-You're done! No more turbo smoke... hopefully.
This will go on a friend's car which has a junkyard turbo. These oil restrictors are a must IMO for older turbos but definitely can't hurt if you have an expensive *** turbo. You can do your own research on hole size but I think 1/16 is the best way to go.
Old Aug 7, 2005 | 04:57 PM
Novtecdohc's Avatar
i will give you 6 bux to make me one for my dsm t25 and ship it to me.
Old Aug 7, 2005 | 05:05 PM
CRXDrew's Avatar
lol, you got to be kidding me. This is quite possibly the easiest DIY eva!!!
Old Aug 7, 2005 | 05:06 PM
CRXDrew's Avatar
I actually was thinking about selling these but the cost of postage and an envelope alone is close to the price of the restrictors. And I have to spend all of 5 minutes cutting/fabbing/drinking beers.
Old Aug 7, 2005 | 05:34 PM
y7turbo's Avatar
Default Re: (CRXDrew)
got one cheaper for ya.. go to napa get a 3an-1/8npt fitting for around 50 cents. .055" drill bit from grainger is like 60 cents and braze the fitting shut.. drill the hole and bam you got a restrictor..
2point2's Avatar
do these things actually lower the pressure? or is it too much flow that is overwhelming the bearings?
Old Aug 7, 2005 | 05:37 PM
y7turbo's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">do these things actually lower the pressure? or is it too much flow that is overwhelming the bearings? </TD></TR></TABLE>
they lower the pressure and flow.. mine with the .055" hole has 5psi at idle and 30 at redline..
Old Aug 7, 2005 | 05:40 PM
Novtecdohc's Avatar
for real make me one. 6 bux
Old Aug 7, 2005 | 05:58 PM
phatrick2332's Avatar
you could also go to most hardware stores/home depot and buy a tiny ball valve of correct size and have an adjustable restrictor. We just bought a few for I.V. fuel system cleaners at work.
Old Aug 7, 2005 | 06:12 PM
bubs's Avatar
I posted this the other day in someone else's thread, but if you have a welder, you can just weld the hole shut on the original fitting and drill a smaller hole in it. I did this about 2 weeks ago and it eliminated the smoking/oil leaking problem on my t3/t04e..
Old Aug 8, 2005 | 02:25 AM
CRXDrew's Avatar
This could of course be done for cheaper by brazing the fittings or welding whatever other fitting you have... of course non-brass fitting etc.
Just trying to give some people an idea of how to do it if they don't have those resources. I have the resources to have a fitting brazed/welded but for a this DIY I thought it be best to have the restrictor as easy to make as possible.
Old Dec 21, 2005 | 06:53 PM
xfrankx's Avatar
Default Re: DIY oil restrictor. Cost = $3 (CRXDrew)
gotta keep this in my watched topics for when i wanna do it
Old Dec 21, 2005 | 07:04 PM
InfamousDC2FI's Avatar
Default Re: DIY oil restrictor. Cost = $3 (xfrankx)
edit - nevermind i need to read post more closely
mcmaster.com part # 2712T44 for restrictor i got
Old Feb 21, 2006 | 01:12 PM
92b16si's Avatar
Default Re: DIY oil restrictor. Cost = $3 (InfamousDC2FI)
im stupid i still dont get how to do this post picks of doing it or crxdrew im from chicago i think i met you once with brian ill give you the 6 bucks for one lol
Old Feb 21, 2006 | 01:16 PM
CRXDrew's Avatar
woah, back from the dead.
I'd make you one but I'm kinda @ school right now. What is tripping you up right now?
Old Dec 4, 2006 | 08:29 PM
cueballsi's Avatar
tracking... good info
Old Dec 4, 2006 | 08:50 PM
sporty240's Avatar
Default Re: (cueballsi)
is 3an considered too big now?
elmalouno
Apr 26, 2009 07:08 AM
Toonz08
Nov 23, 2008 04:49 PM
92integra-R
Jul 3, 2006 10:25 PM
chronoti
Jul 28, 2004 06:32 AM
