d15 rods for turbo setup
Old Dec 3, 2006 | 01:32 PM
xQB21x's Avatar
Default d15 rods for turbo setup
hello guys, a friend of mine decided to modify his d15 turbo setup but when we statred searching for forged d15 (5.279", 134 mm) rods we found out that not many manufacturers produce such rods. And d16 rods which are produced by most companies are 3 mm longer and probably won't fit. So my question is which rods would you recommend for our d15 turbo or maybe there some other solutions to our problem? we are on budget so crower rods (the only ones I'v found for d15) may be too expensive for us. thanks a lot.
Old Dec 3, 2006 | 02:33 PM
b18sihatch's Avatar
Default Re: d15 rods for turbo setup (xQB21x)
for price eagle might be a option, but not sure if they make rods, but they are about the only really cheap/reLIEABLE ROD OUT THERE
Old Dec 3, 2006 | 03:44 PM
ryan89crx's Avatar
Crower makes some....but you're looking at $700+
Old Dec 4, 2006 | 01:28 PM
xQB21x's Avatar
Default Re: (ryan89crx)
does anybody else do such rods cause 700+ bucks seems to be too expensive.
Old Dec 4, 2006 | 02:24 PM
jdmsiR20's Avatar
Default Re: (xQB21x)
im assuming you're using d15 rods from the d15b7, b8?
Old Dec 4, 2006 | 02:35 PM
Turbodseries's Avatar
when you find it, let me know... i'm looking for a set myself.. if not.. i'm gonna have my crankshaft supply thicken up my crank to fit the d16 rods.. of course i have to use a d15z1 or d15b vtec or a d16z6 or else my compression is too high
Turbod the video
http://videos.streetfire.net/v...1.htm
Old Dec 4, 2006 | 02:51 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xQB21x &raquo;</TD></TR><TR><TD CLASS="quote">does anybody else do such rods cause 700+ bucks seems to be too expensive.</TD></TR></TABLE>you're right, it is too expensive.
you are better off buying a 1.6 block and building it. for the cost of 1.5 rods you could buy a 1.6 block, Eagles, and have money left over
Old Dec 4, 2006 | 04:47 PM
DJ_SaNdOz's Avatar
If it's a D15B VTEC you are fine using the D16 rods, if it's a standard US issued D15 then it's going to be cheaper & easier to get a different block from what I have found.
Old Dec 4, 2006 | 08:07 PM
b18sihatch's Avatar
im not even following as to why you would even build a d15 motor? small displacement expendsive rods. d16 blocks are a dime a dozen and have parts widely avaliable
Old Dec 4, 2006 | 09:20 PM
ryan89crx's Avatar
Default Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">If it's a D15B VTEC you are fine using the D16 rods, if it's a standard US issued D15 then it's going to be cheaper & easier to get a different block from what I have found.</TD></TR></TABLE>he listed in the first post that they are 134mm = 1.5 rods
silverskateEF9
31
Oct 6, 2007 07:13 PM
R-Civic
Aug 1, 2007 08:56 AM
