clutch problemo...help porfavor ....
Old Aug 6, 2005 | 05:10 PM
hitvtecgetloud09's Avatar
Default clutch problemo...help porfavor ....
ight so while im driving...i get to a stop sign...after i "stop" i hold down the clutch put the car in gear and klahdfhsdaljhfjhsdf is all i hear...the car wont go into ne gears...but if i put it in a gear first then start it, it runs fine. once i let go of the clutch i hear oihawelkrfjlksaejfklsaehjf agian...btw im using a act stage 2 clutch 6 puck on si tranny with ls-v ne ideas?
Old Aug 6, 2005 | 05:23 PM
HiProfile's Avatar
Default Re: clutch problemo...help porfavor .... (hitvtecgetloud09)
Sounds like your clutch isn't disengaging. When did this start, after you changed clutches or messed with the hydro lines to the tranny?
I'd try bleeding them again - fill up resevoir, pump the pedal to the floor slowly 4-5 times, go release the petcock on the slave cyl, when it slows the squirting seal it again, repeat till the clutch is fine.
Old Aug 6, 2005 | 06:41 PM
Default Re: clutch problemo...help porfavor .... (HiProfile)
well... after i did my swap...on idle my clutch would make a hissing noise untill i would hold the pedal down...and just last nite it gave out on me...and every time i press the clutch pedal down it makes a noise like somehting is breaking.
Old Aug 6, 2005 | 08:55 PM
nocturnaldragon's Avatar
you could very well have a defective pressure plate. Take off the boot and take a peek in there once to see whats going on.
luis666
Aug 15, 2006 01:59 PM
Jmumblez2001
Aug 8, 2006 12:05 PM
B00STED Si
Jan 11, 2005 03:28 PM
ZerboBanger
Apr 10, 2004 09:42 AM
C4wrx
Oct 18, 2002 02:17 PM
