BLOX IM install help ...
Old Aug 5, 2005 | 09:47 AM
christhereefer's Avatar
Default BLOX IM install help ...
Just installed a BLOX IM on my LS/VTEC w/B16 head and everything went smoothly, no CEL's or anything, but now it seems that the motor overheats a little bit. I go to check the coolant hoses and lines and they are abnormally really hot. Coolant is full and everything. Any suggestions?
Old Aug 5, 2005 | 09:53 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: BLOX IM install help ... (christhereefer)
You probably have a trapped air pocket, let your car idle at about 1500 rpm's with the rad cap off, and let the fan cycle a few times and add coolant. It wouldnt hurt to reset your ecu also.
Old Aug 11, 2005 | 05:18 PM
Default Re: BLOX IM install help ... (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">You probably have a trapped air pocket, let your car idle at about 1500 rpm's with the rad cap off, and let the fan cycle a few times and add coolant. It wouldnt hurt to reset your ecu also.</TD></TR></TABLE>
I think this may be my problem, but after doing this, same thing. Any other way to do this?
Old Aug 11, 2005 | 10:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
There a bleeder screw you can use. Its either on top of the thermostat housing or in the front of the motor at the coolent inlet.
jdmchickx
Nov 10, 2011 12:59 PM
illicit^
14
Jul 5, 2007 10:09 AM
shortyz21
Nov 17, 2006 01:27 PM
DsCivicEx
Feb 12, 2004 04:52 PM
Mr. 1582
Nov 7, 2003 03:43 PM
